You'd have to experiment. It won't change it significantly as far as efficiency goes. Probably burn cooler.
Does the air come in under the grate? If so then you can't eliminate it...if not then you probably can...not sure it would make much difference thoughQuestion of the day
Would it be any benifit to get rid of the grate and fire brick the bottom? Direct the draft either up the back or front of the unit. It seems most wood stove do not have grates, even an old bk i used to have.
s there no benefits to firebrick on the bottom?It comes in under the grates, so you'd have to fab up some kind of air channel to bypass the grates. I'm not sure what benefit there would be.
Sand? Is there supposed to be sand between the L brackets and water jacket?No. There's sand or maybe ash beside the grates on that model that insulate anyway.
An updraft water jacketed boiler is completely different than a warm air furnace. It's a cool fairly dirty burn. That's why all the new style outdoor boilers are downdraft models that blow the wood gas into a separate brick chamber to burn off.
Do you know of any hacks for the Hardy H2 to slow the heat out the stack that anyone has had luck with? The one i saw that i was going to try was sticking the 6" pipe 6" into the fireboxI'm going by memory and maybe I'm confused with a Heatmor. Sorry. I'm probably wrong there. But what I'm saying is the ash insulates pretty well, having firebrick underneath wouldn't make a noticable difference I'd guess. The whole firebox is water cooled so it burns fairly cool and dirty. Not saying it doesn't work, I'm just saying tweaking the air inlets into the firebox isn't the main thing that makes it what it is.
Basically it's a super basic updraft burn with no heat exchanger tubes or baffles, just a pipe out the top. A lot of heat lost out the chimney, but it works and there are thousands of them chugging along here in my neck of the woods.![]()
My brother uses a large CB and has found that leaving lots of ashes in it helps...he only cleans it out a few times per winter now...basically when there isn't enough room for woodBut what I'm saying is the ash insulates pretty well, having firebrick underneath wouldn't make a noticable difference I'd guess
Ok thanks. I don't think there's any way around the smoke. Hard to justify getting rid of something that smokes but works to spend 10k plus. I'll have around $1500 in this. Including pipesMy brother uses a large CB and has found that leaving lots of ashes in it helps...he only cleans it out a few times per winter now...basically when there isn't enough room for wood
The other thing that helps is to not fill the firebox...he now only loads only the front half of the firebox, and only as high as needed for a 12 hour...has saved lots of wood this way...she's still a smoky pig though!
Must be a pretty short run...the only brand lines that are worth having are $12-15/ft.I'll have around $1500 in this. Including pipes
Its not just about the smoke...that smoke represents wasted BTU's/wasted firewood...lotta extra work...but like you said before, it will work long enough to save up for an upgrade.Hard to justify getting rid of something that smokes but works to spend 10k plus
Doing my own lines. Foam in place. 50ftMust be a pretty short run...the only brand lines that are worth having are $12-15/ft.
Ah, that's right...sounds like that works fine, as long as the right materials/procedures are used.Doing my own lines. Foam in place. 50ft
Going an extra step. Using closed cell pipe insulation and then foaming in placeAh, that's right...sounds like that works fine, as long as the right materials/procedures are used.
