One man's EKO 40 Illustrated Story - Start to Finish
nofossil said:
stee6043 said:
Update - Well I'm into my second week of burning now. There is much to be learned about how and when to load the EKO. So far what I am experiencing is that the EKO doesn't really want to heat the return water much more than 20 degrees. I think I might start screwing around with throttling my pumps a little but when my return temps are 140 (which is most of the time for me with 1000 gallons of storage) my boiler likes to run in the low to mid 160's and will rarely break into the 170's. If I keep the fire going all day I can get the return temps up to 160 (meaning my lower tank is finally up to 160 on the bottom) and the EKO really starts screaming and can hit 180-190 easily. I see 400 degree flue temps quite consistently.
I do want to adjust the air a bit more. I've got mostly blue in my flame but I think I can cut the primaries even more than 9mm and improve slightly. I just wish I could keep the tank bottoms at 160 but it just won't work for me right now. Fortunately, my water-to-air heat exchanger seems to do a pretty okay job right down to 120-130 supply temps depending on outside temps.
All in all I'm quite pleased. Storage is working. This week I've been back to work and only burn the fire after work when I'm home. We had a rather cold morning here yesterday so I burned two full loads last night. Monday night I ran one and a half loads due to some nice sunshine we were having. All is well in the world...
A 20 degree rise is a pretty common design target. There's some evidence that lower outlet temps translate to higher efficiency, all other things being equal. However, you sometimes need high outlet temps to provide usable heat. If you want higher outlet temps, you have three choices:
1) Use a mixing valve or other inlet temp protection to mix more outlet water into the inlet and raise the inlet temp
2) Use a smaller / slower circulator
3) Manage your heat loads so that there is less cold water coming from storage when you want hotter water for the zones
I use all three techniques. If my space heating zones are calling for heat, I really want the boiler outlet to be around 175. If it's not hot enough, the first thing I'll do is to stop heating storage and other low-priority loads. If that doesn't do it, I'll open a recirc zone valve to allow some of the boiler outlet to return directly to the inlet. If that doesn't do it, I'll slow down my circulator.
NoFossil, would it be "bad" if I were to throttle my circs with the ball valves to control flow? I know to some extent it will increase velocity initially but I should reach a point where I'm decreasing flow and moderating velocity? My thoughts are to slow the main circ since my EKO is so close to the storage. I'm running 007's. I thought perhaps I'm just getting too much flow through the boiler right now. But then again, if 20 degrees is good, maybe I should just leave it alone?
Throttling with ball valves makes me nervous. If it were me, I'd think about how to reduce the portion of your flow that goes through storage. I don't remember what your schematic looks like, so I don't have any specific advice on how to accomplish that.
If you want to reduce circulator flow, some folks have had success using a lamp dimmer. I'd watch temperatures like a hawk, though.
Instead of throttling the ball valves at the pumps,you could add a small bypass loop at the boiler.this can be done many ways.you can put the loop from supply to return and use a ball valve to control flow between supply and return.You could use amixing valve sensing temperature to allow 140-145 degree water tro return to the boiler thru the bypass loop.you could also use a electronic/electrical temp control and a solenoid to do the trick. this is used with cinventional hydronics.I think that it could help your boiler recover faster by returning a small amount of hotter water mixing with the colder return water...hope it helps
Thanks, Seabee. My system does already include the appropriate mixing valve and I always run 140 on the return. My question to Nofossil was regarding reducing the flow through the boiler since my circs have such a small amount of pipe to run. I may ultimately try the dimmer approach....we shall see....
Dont use a light dimmer use a celing fan speed control switch.
Rob
That is one very impressive project! How much of a commitment isit to run? Do you completly shut a system down like this once heat is no longer needed during the warm months?
That is one very cool way to harness the power of heat man!
And I thought moving 300+ gallon aquariums around my home was a pain ha!
Hello Stee , I will be starting a similar project to yours in the new year. " Awesome job"! I have a few questions .
_ Does the 6" chimney pipe work fine ? I see in the manual it says 8"
_ How much for the pallet rack and where to get them . That looks like an excellent way to stack the tanks.
_ Do you have any detail drawings for the tank modifications ,plumbing and piping.
_ What did you do to the inside of tanks as far as cleaning them out .
Cheers Huff.
It takes a month or two to get a routine down, maybe even the first year depending on the quality of wood you burn. For me the time commitment is quite small. I start a fire every day (during cold weather) at 5:30-6pm. That takes 20 minutes or less. I load a half load at 7ish (5 minutes of work) and then I fill it all the way up at 9-9:30ish (another 5 minutes). So on an average day I have just over 30 minutes total into heating my home 100% from wood.
I summerize the boiler in Spring. Quite easy...no running in the summer months for me....Thanks for your kind words, hareball.
Cheers Huff.
6" chimney works great for me, huff. Several of us EKO 40 users on this site are running 6" and I haven't heard anyone complain about it. I paid $400 or so for the pallet rack. I used Steel King racking. If you google them you can find your local distributor. I'm sure you can find cheaper rack but you want to make sure you have properly sized beams for the upper tank. She's 5,000lbs full of water and most standard pallet rack with a 10' bay opening isn't designed to support this much weight. I supported mine in the middle just in case, even though the design load was 6,000lbs+.
I didn't modify my tanks at all. They had plenty of openings stock. All I did was add dip tubes using 1" copper. I also didn't have to clean them (other than a pretreatment) since mine were brand new. Used tanks are quite different. Search "mercaptin" on this site and you'll find some good tips....
Cheers Huff.
If you dont mind me asking what did you pay for the new tanks. I priced them out here, they are $2k a piece new or $1100 refurbished .
I could probably get untagged tanks for $500 a piece
Wow! Can't beat that! Sometimes I feel like a slave to this old stove. One of these days I hope to get my other hearth up and running. I'll have to shoot for a project like yours in my next life haha!!
I love the racks. Perfect place to mount the piping.
For me it's always the wood. I have an eko 60 with 1500 gal of storage It takes a full 8 hours to get the tank close to 180. That ONLY happens with dry wood the eko pushes 185-190 and the tank charges fast. With moderately moist wood ( I really need to get a moisture meter ) the EKO will only hit 170 and the tanks get to 160 if I am lucky.
Seems like you might have the same -- 1000 gal against and eko 40 is a lot of BTU's to transfer. I'm not sure what the 40 puts out max or real world but it sounds like you are right where you would expect to be with the burn times you are talking about. I messed with my settings quite a bit but I found that for me 50% fans, 9-10 mm 60-70% secondaries is where it stays VERY hot and long burns. IF I have dry wood. I got set up last winter and so next winter I hope I am set good for a dry wood supply. I had some massive oak trees go down this year and they will be ready next winter.
I paid $1300 each for new tanks, with tags. Tanks can be had in the $300 ballpark around here used and untagged. The extra 2 grand was worth it for me. I didn't have the ability or patience needed to properly clean used propane tanks.
@stee6043
Your chimney looks nice on the house , I am going to copy your design except for the 90 I am coming out from the house I like to have a cleaning "T" .
Holy old post! Hah. This was my pride and joy of a thread back in the day. There is a Tee on the exit, razvy. You just can't see it and it's not easily accessible. I use the T's on the inside for cleaning....
