How will you heat the house?
YES, it makes sense. In your climate your savings might be somewhat less than they look on paper, due (depending on siting details) to either low air supply temp or heat stealing in the winter. If your boiler is throwing a lot of heat into unused space (like a basement furnace room) and the HPWH is there, the the heat stealing is not really a loss. If the HPWH is in a semi-conditioned space like a v cold basement, it will not deliver the rated EF. If the HPWH is located in 100% conditioned space far from the boiler, about half of the delivered HW BTUs in the winter will come from the boiler, and the other half from the elec grid.
If the anode is described as 'powered', then non-replaceable is not an issue at all...its permanent. If not, they presumably put in a thick enough one to last the warranty period, and you are still aok, unless you know your water chem leads to premature HWH failure.
When I researched this a couple years ago, the Rheem products were inferior eff-wise to AOSmith and GE units. Since the GEs get bad reviews, you might still look for the new AOSmith 50 gallon HPWH.
A fuel burner heating water is a boiler....inside it is prob a multi-section cast iron unit resembling an oldey-style steam radiator with your water on the inside and oil-fired hot air on the outside. The control is a box called an aquastat. The poor HW service means that you likely have a tankless coil....a long coil of copper pipe inside the boiler that heats HW flowing through it. As the boiler cycles on and off, the temp can vary a lot, and delivered water can too. I lived with that for 6 years, and then ditched it. Very happy day.
Had a few people come look at them, but no one followed up so off to the dump they went.
Sure. But there are also bad reviews for the new unit, FWIW.
I think the essential point is that versus oil you might make back the price of the unit in a couple years. In 3-4 years you'll be ahead of the cost of a conventional cheap elec HWH. I would def do the ext warranty on parts and labor, just to sleep well at night.
Nest step: research for rebates from your local utility co. I got $300 from mine.
Also, are you sure your boiler can sit all summer without leaking, most can, but some older units drip a bit when they go cold.
Dropping the oil boiler water temp too far can lead to condensation (water vapor is a product of combustion), and that leads to sooting up of the heat exchanger and premature failure of the boiler. The boiler is likely happier sitting cold (i.e. off) than trying to maintain a low water temp with lots of low temp burns. Most are simply not designed for that.
The bad news...your oil boiler running standby at a reasonable temp in the summer will likely cost 80% as much as using it for hot water. That is, in the summer maybe 20% of oil BTUs go to heating water...the rest is just waste heat dumped up the flue and into your house. In my case I used 300 gallons of oil during the summer, and my hot water BTUs would have been maybe 50 gallons of oil equivalent.
Most boilers can sit cold, unless they are really on their last legs. To avoid rust, if the basement is damp in the summer you can run a dehumidifier or put a (incandescent) light bulb under it.
Personally, once you confirm the boiler can sit cold in the summer, I would just retire the tankless coil completely and pipe in the HPWH rather than plumb a complex primary/secondary/bypassable system.
