Correct. Now to find the adjustmentNo - the boiler maintains set temperature even with no call for heat. From above that sounds like 140-190.
The aquastat cover is probably a rectangular box with a screw on one side....when you remove the screw, you can pull the plate off and see the settings. (Or, take a pic and we can point you in the right direction)Correct. Now to find the adjustment![]()
If your boiler heats you hot water heater then probably yesDo all boilers work this way when running with a tank? I'm wondering if mine is doing the same - it is supposed to be a high efficiency model, but if it is sitting 'on idle' all the time then I can certainly see that I could improve the situation by changing my hot water heating.
You can make any boiler do that,i converted all my oil boilers that dont make DHW to cold start,lest they run all spring,summer and fall maintaining water temp.Newer 'cold start' boilers don't fire unless there is a call for heat - depends on make & model.
Any electric HWH will do the job much cheaper than oil.I have a 30 Gallon electric HWH and it does my family of 5 quite well. Some situations would call for a bigger heater 40 or 50 gal. Such as filling a jacuzzi tub or a family that takes back to back showers at the same time of day. By all means get rid of that oil burnerHi everyone
So bought a house with an oil fired water heater and am looking for ways to keep the furnance off (I heat mostly with wood stove). Anybody in a similar situation? Ive been looing into on demand or solar supplement. Any other ideas? Is the right section?
The extent of my knowledge on solar is http://www.dummies.com/how-to/content/choosing-a-solar-system-to-supplement-your-water-h.html
Thanks!!
!!Hi everyone
Thanks!!
Reckless - do you have access to natural gas?
(Not the beans & burritos kind...)
Interesting..I've got three solar panels for hot water you can have if you're willing to come get them. Sitting in my garage waiting for me to rent a dumpster when I redo my siding. They were functional when I took them down...previous owner said they provided 30% of hot water in winter and most all of it in the summer. I can't attest to those numbers, but I know my oil consumption last summer was very low. The panels heated a 120 gallon water tank which then fed to a tankless heater that provided any boost needed. They were ugly and in my front yard so I didn't want them there and no where else in my yard had the right access to sunlight.
