Good option but 2 P38s will be like $6K?I'd think about getting 2 stoves if yer gonna go full pellet heat. Unless you can run some fancy ductwork, or work miracles with box fans (noisy!), 10+ degrees warmer in the stove room is not likely to happen, IMO. It'll probably be more like 20+ to get your desired temps upstairs. The P68 doesn't screw around. Get too close to it and you'll find yourself cursing saying a lot of HOLY **** and WTF!
How bout two P38's? There's a guy on these forums that has one in his man cave and another that heats the entire first and second floor of his house.
Making heat magically move upstairs and then back to the beds rooms. Been there done that! Don't work that great without ducting.That seems to be a stretch to get heat back to the bedrooms. Others may have some better idea.
AMFM ?,can save enough to get a fair amount of venting.Ok thanks i found a site where they sell refurbished ones not sure if it makes a difference.
Ok thanks i have baseboard heating so ducting to existing is not an option .
Ok what type of house are you in?I i am in a high ranch [super] which is a little bigger than a high ranch & if i install the unit downstairs when you go down my stairs i have a 4 foot hallway that opens up to a big finished well insulated family room but the unit will be about 14 to 16 feet from the stairwell.How long have you had your stove & any problems?
