Chimney is at 28' now, I'm gonna need red lites on top of it if I go much higher!
No, seriously, it drafts like a hoover, if I open the door when the fire is going good, I hafta be careful when closing, it'll suck the handle outta your hand! Baro lays wide open to hold draft down to -.03" when it's cold.
I have 'er running pretty good now, only use about six to nine 4-5" splits per day when it's warmish (30s) and maybe 12 of those when it gets cold. If it gets REAL cold I run the Yukon the same way and just ad a small load in the lil stove upstairs, that'll take us up to 75* in the house on the coldest of days!
I hear ya on the 68 is now 72 thing!
So what is happening to the house temp during this time? Is it holding temp OK or dropping more than you'd like?
Also, how far open is your secondary air?
I read on here about somebody using thermal storage and I knew they had a forced air wood furnace, I'm thinking "say what?!" Thermal storage is normally where the boiler guys fire their boiler once a day, run it wide open clear through the burn, dump that heat into a large insulated water storage tank and then the house pulls from the tank as heat is called for. So I was a lil confused how to do that with forced air, but what he was talking about was using the house itself as storage. Probably doesn't work too well if your place is real drafty, but it makes sense, once the walls and floors, furniture and whatnot are up to temp, not to mention the "storage" in having a 1000# furnace good and hot to pull heat from, you kinda can do thermal storage with forced air. As long as you don't mind a few degree swing in the household temps anyways.
Another thing that helps is to let the ash bed build up a bit on the grates, a couple inches. Just scratch a spot open for air to come up through, let the rest go, coals will lay ona bed of ashes MUCH longer than bare grates. I still have enough coals to do a matchless reload after 10 hours almost daily (at work) 8 hours is NO problem at all, heck, I can get six hours on a load of pine (no coals though) For example, I loaded 3 Red Oak splits and 1 soft Maple this morning at 6:15, it is now 4:30 pm and the house is 70* with it being 25-30* outside today. There is still 100* heat coming out of the registers by gravity, (it would drop quickly if the blower was forced on) Gonna go down for another "feeding" right now. See ya!
