I do but it doesn't do anythingYeah you can only do some much with cathedral ceilings...I bet an audit shows other problem areas that are worse.
You said you run the ceiling fan in winter mode in the high ceiling areas?
The blower motor just started making mechanical noises it did for like 10 mins and now stopped and sounds normal again not sure what that was all about![]()
could just be a vibration causing something to rattle...?
who knows at this pointThe blower just became a wood chipper and took care of that mouse.
That noise you are describing makes me think of too much static pressure in the duct system...or something...ever talked to Lamppa about it?it didnt sound like vibration to me thats fan always sounded strange almost choppy sounding but its never made noise like that before
I think I have heard the noise you are talking about...but I am trying to remember under what circumstances...
That was going through my mind too...He has a manometer, maybe he should put the hose on the other connection (assuming he's using the large scale for vacuum) and stick the other end in the plenum and see what his SP is.....?
I can do that. its just started making that sound again. Im a little confused on what you want me to do. Use the port on the high side to measure it?He has a manometer, maybe he should put the hose on the other connection (assuming he's using the large scale for vacuum) and stick the other end in the plenum and see what his SP is.....?
Absolutely fine IMO...way better than mine!Looks good to me.... @brenndatomu ?
If anything maybe a hair low, but nothing that will make any real world difference, IMO.
wow I'm surprised I figured since everything else was wrong that would be too hahaAbsolutely fine IMO...way better than mine!
My ducts are all over sized due to being made for a monster coal furnace back in 1940...the only way I can get any real SP is to close all my registers...I have learned that SP is not normally that important on a solid fuel furnace as long as you are getting good temp rise through the furnace...mine runs about 40*...70* in, 110* out, on average...obviously those numbers vary a bit based on house temp and the state of the fire in the VF...wow I'm surprised I figured since everything else was wrong that would be too haha
hmmm do you think I would get more heat with bigger ones?My ducts are all over sized due to being made for a monster coal furnace back in 1940...the only way I can get any real SP is to close all my registers...I have learned that SP is not normally that important on a solid fuel furnace as long as you are getting good temp rise through the furnace...mine runs about 40*...70* in, 110* out, on average...obviously those numbers vary a bit based on house temp and the state of the fire in the VF...
I doubt it...how many and how big are they? What is the total sq in? You could always add more ducts...hmmm do you think I would get more heat with bigger ones?
I dont really know to tell you the truth. I have two main runs in the house one going through the left side of the house the other going to the right it brakes of to smaller runs that go to the rooms 9 timesI doubt it...how many and how big are they? What is the total sq in? You could always add more ducts...
Sounds like it is surely enough total sq inches to accomadate the furnace...surprised that your SP is that high. Are there dampers in the duct system that are partially closed?I dont really know to tell you the truth. I have two main runs in the house one going through the left side of the house the other going to the right it brakes of to smaller runs that go to the rooms 9 times
Some of that looks kinda freshly cut...still tests out good on the MC after being re-split and checked in the middle?this is what Ive been burning. I have lots more in my pole barn thats what Im burning tonight. I'm hoping this will give me less coals. Thats why I swicthed to the cherry in my pole barn.
