ugh this stove is driving me crazy. last night i get home and get her back up and running. using begreen's method, i put 2 logs north/south and then 2 smaller ones on top to get running. temp go to around 500 with the damper wide open, then i backed it off to about 1/2 . the temp dropped to about 400 then raked out the coals then put 3 smaller splits in. within 2 minutes the temp was at 500 so i dropped the damper to 1/4. the temp took off to past 750. i freaked. it must have been past 800. i closed the damper and just watched it. took a big box fan and blasted the top of the stove. about 10 minutes went by as it slowly dropped. i dont know what im doing wrong to where i can never control the temperature. one minute it struggles to stay at 300 and the wood smolders, the next it spikes to 800.
could you explain this secondary and primary business for me? i read about it but really don't fallowNot being there we can only guess, but it sounds like the last load of wood should have been thicker splits. Small dry splits can take off quickly. Also it is possible that the air should have been closed down sooner.
What you are seeing is pure secondary burn. It is quite normal and a great light show.
In milder weather I would burn about 3-4 medium-sized (3-4") splits in the F400. You will get better starts and relights if you try this patented Tunnel of Love™ starting method:
Rake coals forward toward the front center of the stove. Then take two ~2" short splits (about 12-14" long) and place them N/S about 4"
It sounds like rocket science now, but you'll figure it out quicker than you think. But even when you have experience, it will surprise you once in a while. I predict you will have a warm winter...this is going to be a long winter
It sounds like rocket science now, but you'll figure it out quicker than you think. But even when you have experience, it will surprise you once in a while. I predict you will have a warm winter...![]()
