As some of you know, I finally decided to upgrade to a "smart" woodfurnace. The PSG Caddy Advanced has self regulated combustion, easy heat exchanger clean out, glass door and optional ECM blower motor. The unit is close to 900 pounds and is built like a brick shithouse.
The ECM blower is quiet and the furnace regulates for comfort and efficiency. If there's no call for heat, the blower will shut off and cycle on low to remove excess heat. The combustion air will go to it's cleanest lowest burn. If there's a call for heat the fire ramps up and the blower kicks into high. The home is much more comfortable with even heating.
The video below has 5 splits, loaded at 8PM last night (2.5 hours into the burn). This load lasted 8.5 hours. I woke up when I took this video and my air temps 7 feet from the plenum were 122 degrees in the main trunk.
![[Hearth.com] New PSG Caddy Advanced [Hearth.com] New PSG Caddy Advanced](https://www.hearth.com/talk/data/attachments/284/284751-eece07379cd8bae6eadd626ba32905f9.jpg?hash=pW11TR7mYh)
