- Nov 12, 2006
- 66
Hi everyone. I would like some feedback on my new Oslo. The setup is simple. About 5.5 feet of 6 inch single wall pipe (with two 45 elbows) transitioning to 8 inch single wall for 1 foot and then 8 feet of 8 inch class A double wall insulated chimney. I can get the stove going to 350 degrees no problem. My problem is there is smoke out of the stack. I thought I would be getting away from that with the Oslo. I can reduce the smoke if I get it up to 500+ degrees with the intake wide open. But for long burns with the air intake nearly closed, I get smoke out of the stack. Is this my wood? Too green. I am using some oak and black birch split in early spring. Or do I need to get the stove up to VERY high temps to maintain the slow burn. I am not seeing the extended burn times and am getting a lot of smoke when I do.
Thanks.
Thanks.
