Hi all
I have a friend building a new 1200 sqft bungalow with a walkout basement. Standard construction for our region in Quebec ie
6" fiberglass walls, R 40 ceiling and basic double pane windows. He has heated his 100 year old farmhouse with a 10 year old
Benjamin wood/oil boiler. //www.benjaminheating.com/brochures/DO110_180_English.pdf He will be demolishing the old house and can therefore reuse this combination boiler in the new bungalow. He wants to heat with wood(he is a farmer with lots of supply).
He does not want a woodstove in the main floor living area. ie he wants the woodburner in the basement. He is not crazy about adding a storage tank. The question is
1) Go with radiant floor in the basement slab, and under floor on the main floor and reuse his Benjamin wood/oil boiler?
2) Use a furnace such as the caddy or mini caddy and go with wood hot air?
We are both a little worried about overheating with the wood boiler, however the basement slab would provide a fair amount of storage and could serve as a heat dump.
My suggestion is to install pex tubes in the basement slab, reuse his existing boiler, but what is the best (cost effective) way to heat the main floor? Will the basement slab provide enough heat for the mainfloor as well?
Thanks for your input
Stewart
Stewart
