A king with a 6" flue would never pass the emissions testing would be my guess.Bold new graphics?
A 6" king? They dropped US sales of furnaces.
The same reason that the regency 5100 and the buck 91 have 8" vents you need volume to make them work properly. I am not saying that bk could not redesign it and make it work with a 6" vent but it will take quite a bit of engineering.If I understand correctly, the 6" flows less than an 8" at high burn rates but flows way way enough to keep the firebox evacuated if the max caddy can vent its 4.9 CF firebox through a 6". I really can't see any good reason for the 8" relic of the past. Lower flow rates due to chimney restriction, if that's even an issue, can only enhance the combustor's ability to eat emissions. Low and slow is most efficient and cleanest for any of the models.
Aw, c'mon; We we'll keep it under our hat...I cannot add anything else at this time!
So glad I didn't get a princess, I would probably be kicking myself right now.
Wait until you see the next one! And thank you.Good deal. That's a nice looking insert Chris!
Meh, small firebox.
It has NOTHING to do with the Briarwood and the door/glass is much bigger. Nice try though.I will say, that Sirocco 25 sure does look like it was built off the Briarwood frame.
There's a limit to what cats you are going to be able to cram into most fireplaces, and it seems to be about 3 cu.ft. There's the Kuma Sequoia insert which claims 3.6 but I don't know how that translates to real, usable firebox size...Meh, small firebox. If they announce a King insert, I WILL kick myself for buying a princess this year
Woody...bigger boxes can be built, but at the price of making combustor inspection and replacement a nightmare!There's a limit to what cats you are going to be able to cram into most fireplaces, and it seems to be about 3 cu.ft. There's the Kuma Sequoia insert which claims 3.6 but I don't know how that translates to real, usable firebox size...
