Hi, Folks: I just instaled a Morso 2110. We inserted into a raised hearth, and are drafting through the top. On starting a fire, we are having problems getting smoke over that ceiling which blocks direct flow to the chimney. i assume they put that in there to deflect heat and reburn some of the gases. It takes about five minutes of burn to get that flu heated and get smoke up it. In the meantime, I am getting almost all of that smoke backflowing into my playroom, and it is going to ruin my house if it doesn't stop. I've stopped using newspaper and moved to fatwood, which has cut down on the smoke a bit, but it is still a big problem. And fatwood smoke is black pitch-filled stuff which is even worse. Even when I try to heat the flu a bit with a small flame, holding a piece of burning fatwood or newspaper up near the chimney intake, I can't seem to get it to draft that well until I get a significant amount of heat. I was thinking of taking a blow dryer before starting the fire, and blowing hot air up there for about five minutes before lighting. Or getting a propane torch and doing the same. I am at the end of the game with this thing. Either it starts to draft or it goes...Any suggestions? PS: chimney is 6-inch stainless steel pipe, insulated, runs about 15 feet to chimney top.
Thanks, CT
Thanks, CT
