mgapinski said:Sotz Corporation (at one time of Columbia Station, Ohio) made a 15lb "monster maul". Who knows where (if?) they're made now? A new company name? Where can I get one of these? thx!
11 Bravo said:My fellow Michiganders.........Why would you want to swing something that heavy.......Maybe someone out there has the physics skills, but seems that you could get a faster head speed with a 8 or 10 # maul, thus getting a better / more effective strike....Someone out there has to have done the math on this at one point.....
Gooserider said:However while the monster you mostly just let it fall while you guide it, but don't try to accellerate it that much, you can accelerate the 8lb sledge to a much higher degree by putting some muscle into it, and that will let you get more kinetic energy into the lighter hammer, and bring the momentum into the same range.
.DiscoInferno said:Gooserider said:However while the monster you mostly just let it fall while you guide it, but don't try to accellerate it that much, you can accelerate the 8lb sledge to a much higher degree by putting some muscle into it, and that will let you get more kinetic energy into the lighter hammer, and bring the momentum into the same range.
Not to belabor the point, but while it's true that you will be able to accelerate the lighter maul to a higher velocity, it doesn't necessarily follow that you will be able to put more KE into it than you can into the heavy maul. If you put the same effort (energy) into the downswing for each, you will add the same KE. The only way the lighter maul gets more KE is if the human force-velocity curve favors higher velocities. But some googling indicates that the force-velocity curve of muscles is maximum at rest and decreases as the velocity increases. Since energy is force acting through a distance, this suggests that you can put more energy into the slower, heavier maul than into the faster, lighter one. At least for one swing
IMHO it's a useful tool, I drag it out first when I'm splitting...Now I'm going to have to go get a monster maul, just to see if any of this theory holds water...
Gooserider said:.DiscoInferno said:Gooserider said:However while the monster you mostly just let it fall while you guide it, but don't try to accellerate it that much, you can accelerate the 8lb sledge to a much higher degree by putting some muscle into it, and that will let you get more kinetic energy into the lighter hammer, and bring the momentum into the same range.
Look at the equations, the curves are different between kinetic energy and momentum. Momentum is a product, so the result stays about the same as long as the change is proportional - If I reduce the mass by a third, and increase the velocity by a third, the net momentum remains the same.
OTOH, Kinetic energy goes up as the SQUARE of velocity - I make the same change as above, and end up with MUCH more kinetic energy because the velocity increase is squared, while the mas decrease is only a multiple.
Gooserider said:Well, I may be able to get more definitive answers soon - The GF's parents are both Oxford physics Ph.D.'s and retired professors, and the chair of the Mass LP, and Presidential Candidate George Phillies is a Ph.D. and proffessor at WPI. I've posed the question to all three, will see what the experts say...
That said, my impression is that the lighter maul is moving faster when I hit with it, I don't know if it is a 3rd faster (to keep momentum constant) but it certainly is fast enough to have a higher kinetic energy. However it doesn't seem to have the same momentum...
I guess the parrallel question is which will do more damage to a structure - a VW Bug at 60MPH, or an 18 wheeler at 30MPH? Given the square function of velocity, I suspect the Bug would have higher kinetic energy, but it just makes a splat - the truck has the momentum advantage, and takes down the structure....
I think momentum is the more important factor, because it represents inertia - the tendency of the maul head to keep on moving... The thing that splits the wood isn't just the impact, but rather the penetration of the head into the wood which transfers the downforce of the head into the right angled spreading force that separates the wood fibers. The light hammer tends to stop when it hits the surface, transferring it's energy randomly into the round where it dissipates. The slower, but higher momentum Monster tends to penetrate deeper because it just doesn't want to stop, and thus transfers more of it's momentum into the spreading force of the wedge shaped head.
k = P^2 /2M
K = KINETIC
P= MOMENTUM
M= MASS
The HEAD WITH MORE k ALSO HAS MORE p.
Try THE EXPERIMENT.
Also, there are issues with overloading the back with swinging heavy objects.
However, these are moderately different in moment of inertia.
I shall repeat the lesson from the professional construction worker, dealing with a sledge hammer. You get it up there and drop it. You don't really push it much; it's weight should do the work. This protects your joints for old age.
The moments of inertia MR^2 differ by a factor of two.
