Or Edmund Scientific large fresnel lens in the sunshine...Heat Pump and wind.![]()
Agreed Keurig is not great coffee and it's an environmental disaster. (Each pound of coffee sends 50 K-Cups to the landfill.) We have a Capresso coffee maker that has an insulated carafe for when we are in a hurry and want the coffee ready when we wake up. But usually we heat the water on the stove, then the coffee made in a Bodum press pot, then poured into a thermal carafe. The grounds go into the compost or on the strawberry bed.
http://www.carbondiet.ca/green_advice/food/k-cup_coffee_maker_garbage_an_environmental_issue.html
Plus, you are tied to what is available in those cups if I am not mistaken. Kureg coffee maker, .75 KwH for 24 hours
You must drink a lot of coffee.
Update the darn UV light system used .90 KWH in 23 hours.
Whats a VCR? I use 8 KWh of power a day in a 3100 sg ft house.I have the following setups
-well pump
-electric dryer - energy star
-electric range
-geothermal - energy star
-mostly leds or cfl bulbs
-energy star upright freezer
-energy star double door fridge
-energy dishwasher
-small dorm fridge (for beer)
I unplug all VCRs, game consoles, phone chargers, kids toys. During the summer with out the geothermal running my base use is 30 KwH per day. I have never been able to get lower than this. I have had an electrician out and we can't find any issues. Does that seem excessive to anyone?
Id never trade my Keurig for some other maker! it only takes a moment in the morning to warm it up so its ready to go. Shut it off when done or usw the 2 hour off option.If you want to reduce your coffee maker power consumption, get one that has an insulate carafe instead of a burner to keep it warm. Cooks the coffee less too which some consider to help hold the flavor better. Less standby power loss... not sure I'd do it just for power reduction though, have to like the coffee and drink it before it gets too cold too![]()
Not really it turns in at 5:30 AM we drink two cups. We drink two more and take them to work, it shuts off at 7:15. We only use the k-cup basket and put in our own dunkin donut.
This thread is a great thread,
Yeah, but there is better coffee to be had, and for much less. I just received in the mail yesterday, 5 kg of primo German coffee for $110. Nothing this good is available in K-cups, and even the mid-grade stuff that can be had in K-cups averages $25/kg (almost as much as primo stuff in 500g bags). Yes, you can use a reusable basket in a Keurig, but then the convenience advantage is eliminated, and you're left with just a substandard coffee maker, which doesn't brew hot enough. The Keurig is great for convenience in an occasional single-cup maker, but there are much better options for your daily use / making multiple cups. Check Bunn commercial duty, or Technivorm.Id never trade my Keurig for some other maker! it only takes a moment in the morning to warm it up so its ready to go. Shut it off when done or usw the 2 hour off option.
That's very impressive. I think we average 50 - 55 kWh/day, when the AC is not running, and over 80 kWh / day in July.Whats a VCR? I use 8 KWh of power a day in a 3100 sg ft house.
I just finished my morning cup. I watched my monitor & watch while my Tassimo did its thing - also was trying to clean up some dishes at the same time, so my data is a little bit fuzzy. But it took 2 minutes from start to finish, and my monitor showed it used 3000 watts for about 45 seconds, the rest of the time it didn't register anything - guess the pump itself doesn't use much juice. So .75kwh would make me 20 cups of coffee.
May I ask what brand?That's a lot of juice. Do you have it on a 30 A circuit? My express water heater uses 1500 W and boils up to 7 cups of water in about 5 to 6 min. In the morning, I turn it on, take a bathroom break and when I come back it is usually done already.
yep. here it is:We might need a coffee thread in the Inglenook, this is getting a bit sideways...
No. All heat and hot water is via oil, roughly 1 gal/day for hot water in summer, more in winter.Holy moly. That's a lot of power. Must be electric hot water heating. You use half of my annual electricity usage in July alone. But I'm still heating my water with propane and my house with oil and wood.
This device clips to the two hot legs entering your electrical panel with donut type CTs. Perfectly safe, but remember that your main breaker probably does not deenergize these wires (above the main breaker) so they will remain HOT even while the Main Bkr is open.Is this the meter that everyone likes?
http://www.amazon.com/Efergy-E2-Wireless-Electricity-Monitor/dp/B003XOZG0Y
Question: If the only connections are the amp clips, how does the device know the actual voltage? Does it just ask the operator to input the nominal voltage?
I ask because my provider routinely delivers at 125 to 128 volts per leg. I think they do it knowingly and enjoy the extra revenue.
That's the one I have. The sample rate is adjustable down to 6 seconds. This is the only shortcoming, I wish it was every second but that's just because I am impatient.
Yes you install it around the hot wires between the meter and the main breaker. It's not unlike holding onto the cord to the toaster when it is plugged in, the wires are insulated so you can touch them. Just don't touch the energized parts of the panel.
You can also clamp the CTs around individual circuit wires if you want to log a device like a water heater, hot tub, or heat pump.
I stare at this meter many times per day. The display unit is wireless and I have it mounted in my living room on the wall beside the weather station.
I'm curious about how much you have reduced your energy consumption as a result of having this meter and at what cost? Has the reduction been a result of lifestyle changes or spending on more efficient lighting, appliances, etc.?
(I see this unit on eBay for $39 that can sample every 2 secs.)
(broken link removed to http://www.ebay.com/itm/Wireless-Electricity-usage-Monitor-power-energy-monitoring-system-/321347810282?pt=LH_DefaultDomain_0&hash=item4ad1d273ea)
We gave our children an extra allowance every month to cover a quarter of our typical electrical bill. The rest of their allowance they earned with chores.The educational aspect has been great as well, my young children also watch the monitor and we see how long it takes for the water heater to recharge after mom's shower, a little simple math and we can estimate the cost of heating that water.
Makes me think I should park my spare TED 1001 at my sisters house for a few months. I'm sure her 4 kids could use some retraining about not leaving so many things turned on...I like that you folks are using this as an educational tool as well as a way to find wasted energy. That is cool.
