why monitor use just to cut kw's. cost relates and reason to cut,save ,don't use it.
What?
What?
I have a Kill A Watt Meter but I am interested in the well pump, dryer, electric range and other 220 volt items.
The reason I want to monitor is because I want to be able to actually measure what appliances are consuming. I have a Kill A Watt Meter but I am interested in the well pump, dryer, electric range and other 220 volt items.
Last year I replaced my well pump and I reduced the daily KW consumption about 2 KwH's per day which is $.30 cents a day or $9.00 per month.
I put an amp meter on my well pump and observed this behavior, initial high current at motor start then constant current until the shut-off pressure is reached.Maybe, since it is a centrifugal pump, the wattage will be constant but the flow of water being pumped will reduce as pressure goes up.
I have the following setups
-well pump
-electric dryer - energy star
-electric range
-geothermal - energy star
-mostly leds or cfl bulbs
-energy star upright freezer
-energy star double door fridge
-energy dishwasher
-small dorm fridge (for beer)
I unplug all VCRs, game consoles, phone chargers, kids toys. During the summer with out the geothermal running my base use is 30 KwH per day. I have never been able to get lower than this. I have had an electrician out and we can't find any issues. Does that seem excessive to anyone?
Is your well pump a deep well? You could have a leak down there?
30 kWh/day, I'd be looking hard to find something....
..... my base use is 30 KwH per day. I have never been able to get lower than this. I have had an electrician out and we can't find any issues.
I wonder about this, Highbeam. We have two new'ish refrigerators with vastly different times to thaw in a power outage. I'm talking maybe 5:1 ratio, although it's tough to say for sure given different installation conditions. I'd bet some refrigerators are real energy hogs, whether it be from age, manufacturer's defects (probably my case), poor design, improper installation...I was surpised at how little the fridge used. I forget the exact number but hardly anything and this is another one of those energy hog myths. I wouldn't replace a fridge until it breaks or is needed for some other reason than energy efficiency.
Loan me that thing for a day or three, if you want some numbers to make you feel better about your situation.I put my efergy e2 up a couple days ago. Even with everything I know of idle, I am at 360W.![]()
The clamp on ampmeter or a whole house monitor will find your leak. You investigate each circuit one at a time until you find the culprit.I am,
- new fridge 12/12
- new dryer 11/12
- new dishwasher 01/13
- new well pump 5/13
- new satellite system that uses less electric than my old satellite 3/14
I paid an electrician to come and inspect and he found no vampire loads. He installed new ground rods and brought the panel back into compliance.
My well is only 75' deep. Last May I replaced the pump, electric wire, pipe and bladder tank. When I did this my electric usage went down 2 KwH per day. I can guarantee nothing is leaking down there.
I also have a sub-panel in my garage. It is fed overhead, three breakers, lights, outlets and a 75 watt sodium vapor light.
Is the pump in the well? It doesn't take much some times to get a foot valve to seeping a bit - and with the pump in the well you'd never know it was running. Unless you had a monitor of some kind on the circuit.
That is a huge base load. My average total consumption runs in the 20kwh/day area. You've got something sucking the juice.
EDIT: Do you have a septic system? Any pumps in that anywhere?
That's a fairly big draw for nothing obvious using power - about 1250 watts 24/7.
-well pump
-electric range
-energy dishwasher
You've got an all electric situation. In the summer, even without the geo running, you've got kids so you're using the range 3 times a day, the electric dryer probably does a load a day, plus the dishwasher. All that at 30KwH a day ain't bad.
Johnny,
I have a geothermal system also. It has resistance heating elements that are used only in emergency heating mode. I had a contactor in the system go bad once and one of the elements was energized 24/7. If I recall correctly it pretty much doubled (or more) our energy usage.
