MH's aren't exactly stoves or fireplaces. Just my opinion but without a special area for these types of heaters, would think The Green Room might be a good place .
This area is for discussion and links of renewable energy and conservation NOT related to stoves - such as solar, wind and water power as well as conservation, ethanol and other evolving technologies. Long debates may be moved into the Ash Can....we would like this area to be a resource!
How do you sweep a MH? I have to think, even with the intense fire, it needs to be done every once in awhile?
I know it is illegal to pass someone on the side of the road in Alaska during the winter if car broke down. So, what you say makes sense - how could a homeowner be told to stop burning in minus degree temps if all they had was a pre-EPA wood stove?Often a wood heater is exempted if it is the sole source of heat. This is not based on efficiency.
I am going to guess you have never actually been to Europe? I lived there for a decade. Married one and brought her home.
You want to know what Germans think and say about America? I can tell you first hand. Her whole family wants to come here on vacation, they don't want us to go there. Her parents come over, rent a car and just freeking drive for days. They have seen more of this country than I have! Yep most of them live in small, multi family/generation homes. Where my wife is from, Erlangen Germany, in Bavaria, bare ground, if for sale, would be about 4 million euros an acre, and would cost another million to get/have anything built on it(permits and such). That's why. Her family comes to visit, and just marvels at the 10 acres of woods, huge house and beautiful open views of our little valley, the fact that the forestmeister doesn't tell me IF I CAN, or WHICH deer to shoot, or tree to cut. etc etc etc.
ID have to call BS on that 1/5 as much wood claim. There are only so many BTUs in a given piece of wood. No matter what kind of stove its burning in.I found these, too. He says a masonry heater only uses 1/5 the amount of wood as a steel wood stove - wow, this is hard to believe.
"....Inside, masonry stoves (heaters) burn hotter than metal wood stoves, and masonry heaters winding maze of flue (baffles) warms the surrounding masonry, which than emits heat for 18 to 24 hours. The temperature can reach 2000 F inside some masonry heaters (vs 700 F inside a metal wood stove), .. A metal stove gives out its heat rapidly, thus never allowing the inside combustion temperatures to achieve the 1100 F plus needed to ignite all the gases...."
"...Because the stored heat radiates slowly from the masonry, it is only necessary to light a fire once a day in most cases. In really cold conditions, you might need to light two fires a day. Metal wood stoves must be tended to continually, and they fluctuate from peak high temperatures, to no heat, when the fire goes out. If you tamp down the flue on a metal wood stove you increase the emissions of pollutants as the combustion of the wood is incomplete.A masonry heater will use 1/5 (or much) less wood, then a home heated with a metal wood stove. All well designed masonry heaters easily outperform the highest rated
EPA certified metal wood stoves. And like a wood stove, a masonry heater can exhaust through a metal flue pipe....."
