I believe masonry heaters are superior heating devices as compared to wood stoves. Yet it seems no one else realizes this. The real question? How has an inferior appliance (the wood stove) come to dominate the American market as the #1 wood burner?
Fireplaces have been banned in new construction in Washington and Oregon because they are so innefficient. Are wood stoves next? A wood stove is a metal or stone box with a pipe - and a little gadgetry to increase efficiency. A masonry heater is a thermal mass with channels. Why are masonry heaters so far advanced to inferior wood stoves?
* they get over twice as hot in their fireboxes - which means? Means the burn is more complete. Which means you use less wood for heat.
* masonry heaters create an even heat - you're heating a big mass, wood stoves go to extremes - from hot to cold (they are just a box after all, what do you expect?)
* Wood stoves must be attended to and fed constantly, sometimes. Masonry heaters are fed once or twice a day - done.
Masonry heaters are relatively unknown so the parts for them are overpriced and the construction costs are inflated. But if more do-it-yourselfers got interested they could build there own superior appliance for what a new wood stove costs. So good bye woodstock wood stove and hello small contraflow masonry heater.
This masonry heater should cost me between $1000 and $1500 to build myself. All one needs is knowledge, firebrick, some rocks or old bricks, a good door (and a few other gadgets), and a specific type of mortar. The piping should be the same as a wood stove. C'mon man, why are you using a wood stove?
