Very interesting, Would. So that's what the infamous stainless piece looked like... thanks for posting it! You may have the only two known to currently exist ![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
precaud said:Very interesting, Would. So that's what the infamous stainless piece looked like... thanks for posting it! You may have the only two known to currently exist![]()
That's a Sherwood, radiant model. Looks like they took good care of it. A LOT of stove for 400 sq ft, I'd say! I wonder how much value they're giving to the pipe. I'm not a big fan of the air-insulated pipe. The Kents run hot in that first few feet of pipe so I'd definitely use single wall up to the ceiling connector. If you don't need the pipe, see if they'll sell without it for 350-ish.
Sounds like a plan - good luck with it.
The Sherwood certainly heats up fast, compared to anything else its size - you'll absolutely love that!
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------First, a few technical details not mentioned in the manual that should be useful for understanding. maintaining, and troubleshooting a Tile Fire/Sherwood.
Tom Oyen gave good instructions on checking the damper control rod in this thread:
https://www.hearth.com/econtent/index.php/forums/viewthread/65588/#748929
The next two pics show the bypass damper in open and closed positions. Yours should be able to move between these two positions easily. The steel plate serves as a stop for the damper in full open position. The damper "puck" floats on the baffle surface and on the control rod end (i.e. it is not attached to the rod) so it should accommodate a reasonable amount of warpage of the chamber bottom.
I first used a plastic kitchen spatula to scoop the ash into the firebox below. While doing so, I unknowingly pushed some of the ash between the damper "puck" and the steel plate. I then tried operating the damper control rod, and it was binding toward the full open position. Odd, since it wasn't binding before I cleaned. So I vacuumed out the area behind the puck, and then it operated smoothly again. So if yours is binding, clean out this area in front of the plate before you pronounce your baffle warped.
The name 'Kent Tile Fire' mystifies and intrigues....all are compelled to click on it in an effort to find out more.12,800 views... wow! I guess there's a lot more interest in the Kents than normal post topics on this site would suggest...
Hi, Ive been following this thread for awhile. I too own an example of the lost tribe of Kent. I have been burning this stove for 20 years. At first I hated it as it was a dirty burner and not very stylish with its base. About 12 years ago I took some steps to change our relationship and they worked. I lined the inside with full sized fire white fire brick from a glass kiln. Next I drilled another 1/2# hole into the air intake. The brick made the stove so hot that the previously always dirty glass cleaned right up and the heat out the front is impressive. The extra air helped to clean up the smoke during the initial warm up burn. I also burn sappy pine and the extra air really helps to burn the excess black smoke. Was it my mods(totally worth it) or just age that has caused my baffle plate to warp and crack? Maybe both. Funny thing is that with a very broken baffle the stove burns cleaner than it ever has, but seems to be using more wood. I found another Kent in the garbage of our local woostove store and am getting it ready for a trade off as it is in good shape. I am going fire brick it and drill the holes in the airwash shield. I might leave the intake stock this time. My question is do you think that adding some steel round bars on the bottom of the baffle plate(for strength against warpage) would mess with the flow of smoke in a negative way? Also on the front edge of the baffle do you believe that I need insulation or could a simple defector work?Thanks Woody, I hope all is well with you. Yes, pinon on average has a higher pitch content than most pines. I burn mostly pinon but the stuff I was describing is really more like fatwood. It was a rookie mistake to burn it!
I would guess that species growing along a river in Socorro would be SIberian Elms, cottonwoods, and the like... nice looking trees but not what you'd want to burn if you had other choices...
I just noticed this thread has over 12,800 views... wow! I guess there's a lot more interest in the Kents than normal post topics on this site would suggest...
The bars I spoke of would be welded. The extra air intake was added with the thought that more air would make a faster burn on initial start up=less smoke. My other stove is a Fisher and has a lot more intake volume and less start up smoke. Since I added the bricks and the air hole at the same time I am not sure if it made a big difference. The hole is drilled right in the center of the intake slider and is only open under full throttle, and closed at about 3/4 open on the slider. I can say for sure that it boosts the fire. What I cant say for sure is if the boost overheats the stove and warped the baffle or if the new intensity of the much smaller and hotter bricked box did it. My stove came with the add on front baffle insulator other posters have shown. It looked like a cheesy add on and was promptly ripped off in my foolish earlier days.(not to be confused with foolish present days) Sorry if I overlooked but what was the material you used for your insulator? Do you feel that is durable? Would a piece of thin fire brick work or would that be more reflective than insulating? My chimney is 17 ft. triple wall and draws well. I was getting ready to trash this stove and buy a new EPA clone when I decided to do a search and found this thread, justifying my earlier mods and adding more. I now look at this stove more fondly, loving that window and still hating the base. thanks for posting your workaqua, it sounds like your reasoning has led you in similar directions as mine. I'm puzzled on the extra intake air hole, and wondering about your chimney. Do you have good, strong draft?
Sorry to hear about the baffle warping. The steel bars on the bottom wouldn't be a biggy for "smoke flow", but they would likely warp unless welded in place. The insulator across the first 4.5" of the baffle has less to do with directing the smoke and more to do with insulating that area to keep temps high in the region where the bleed air is introduced. A deflector won't do that.
Ok after cleaning and looking at the stove for a good part of the day, I have more questions. What do you think about locating the air wash bleed holes up higher? It would be possible to drill them through the rectangular intake ports. In your opinion would there be any advantage to having them up higher and closer to the baffle holes? I also found the front baffle add on piece that I tore off, complete with insulation. Looking at more modern stoves I have seen some with fire brick instead of steel for baffle material. What do you think of insulating the whole underside of the plate with Kaowool or thin sliced brick? I really dont want the new stove to warp. It seems to me if it were insulated the steel wouldnt get hot enough to burn off the gasses. Is my thinking off? I always assumed the burn off was happening above the plate in the secondary chamber.But if it is burning off the gasses in the fire box then brick lining the plate would make sense????? I used full 2 1/2" bricks on the sides and bottom,with split bricks for the back wall. As I said before the box is smaller and the heat is intense. Intense enough to be the probable cause of the warped baffle plate. I would sacrifice some more space if bricks on top would reflect more heat, burn more unburnt gasses and stop the warp. Whatcha think? I have tools and a fresh stove laying in the shop and am willing to consider any ideas you might have and didnt do to your own.The bars I spoke of would be welded. The extra air intake was added with the thought that more air would make a faster burn on initial start up=less smoke. My other stove is a Fisher and has a lot more intake volume and less start up smoke. Since I added the bricks and the air hole at the same time I am not sure if it made a big difference. The hole is drilled right in the center of the intake slider and is only open under full throttle, and closed at about 3/4 open on the slider. I can say for sure that it boosts the fire. What I cant say for sure is if the boost overheats the stove and warped the baffle or if the new intensity of the much smaller and hotter bricked box did it. My stove came with the add on front baffle insulator other posters have shown. It looked like a cheesy add on and was promptly ripped off in my foolish earlier days.(not to be confused with foolish present days) Sorry if I overlooked but what was the material you used for your insulator? Do you feel that is durable? Would a piece of thin fire brick work or would that be more reflective than insulating? My chimney is 17 ft. triple wall and draws well. I was getting ready to trash this stove and buy a new EPA clone when I decided to do a search and found this thread, justifying my earlier mods and adding more. I now look at this stove more fondly, loving that window and still hating the base. thanks for posting your work
