Hi all,
Set up my fire about 30 minutes ago and piled about 6 crumpled newspaper then put some kindling pieces on top to good pile. Then put 2-3 pieces placed around the top. Damper bypass was open (straight up shot through the chimney), air intake wide open, door cracked.
Lit newspapers in 4 different locations....smoke starts pouring out the door longer than I found acceptable so I closed the door.
Smoke started POURING out through the front intake into the room. Closed the intake but it was still coming, albeit slower.
I guess this is what we call a "no air going up chimney" situation
Finally opened some windows and lit a piece of newspaper directly below the chimney uptake, and after about 5 seconds I could see the draft forming and we were good to go.
38 degrees outside, 13' insulated liner up an exterior chimney, now roaring away at over 400 degrees and rising...
Joe
Joe
