..Door has been closed for an hour or so..damper wide open...temp gauge in rr corner..it read 375 stove is full of red hot coals and some wood about burned down to coals
I would try to keep it under 700 but I wouldnt think going over by a few hundred once in a while would hurt anything. But im sure Jake would know better then me. I run a cat stove. lol
First thought would be wet wood.If the wood you put in tends to burn black a lot and not flame...maybe just turn to coal chunks..any ideas?
The oak was from standing dead trees, split, stacked on pallets for about 10 months and covered.
I'll wager that if you have one of your larger splits of that Oak at room temp, re-split it and test on the freshly-exposed surface, you'll find that it is 25% moisture content or more. Oak, one of the slowest-drying woods, needs to be stacked in the wind (top-covered only) for two years at least, but really gets dry when it has three full years in the stack. Right now I'm burning White Oak split and stacked four years, and Red Oak that's been drying five years. Now, if an Oak was dead standing for ten years, and wasn't too big in diameter, it might be getting somewhat dry. I've cut dead standers that had no leaves for several years, and the wood in the trunk was around 35% moisture. Get a cheap moisture meter at Harbor Freight, $15. Get some soft Maple (Silver or Red) and don't split it too big. Stack it in the wind now and it will be fairly dry by fall. If you have access to a wood lot, go out there now and find some small (6-8") dead standers with all the bark gone, they may be ready to go into the stove immediately, with moisture under 20%.If the wood you put in tends to burn black a lot and not flame...maybe just turn to coal chunks..any ideas?
Some of the Jotuls are known to require strong draft, I believe the Castine and Oslo are two of them. Read your manual and see what the recommended chimney height is, then add a couple feet more. Heck, I usually read stove manuals two or three times..good info can many times be found.From the outlet behind stove to top above roof is probably 13 feet or so..
How about burning pines in the stove?..I love to hear these answers....Remember I lived In Alaska for 41 years and the only wood up there is spruce, birch..softwoods. Had no problems, plenty of heat, only cleaned flue once a year. Maybe adding some pine to my hardwoods would give out lots more heat.
Start now and you should be good to go by next burn season.How long to season pine usually.if it was live. I need to thin some out anyways.
Yes, scab some single wall pipe on top of your chimney to see if it will draft better ( it will). Maybe buy two or three snap together sections from tractor supply for your testing. Once you have figured out what the magic number of sections needed is you can then buy your class A.I can say I do have mixed dry and wet wood in the mix...definetly...Can hear it steaming sometimes..Also I went on the roof..I have multiple roof levels. The roof the flue comes thru is definetly lower then the roof line 10 feet away..probably by 2 feet or a lil more..So , the pipe thru the roof is chrome triple wall I believe. Can I just scab on a double wall section for now, to see the difference..The pipe thru the roof is 4 feet higher where it comes thru roof..
