Pros : starts in a snap ,great draft from my 26' external chimney and 4' internal pipe.. Cleans up easy. Airwash is fairly effective. Cons Eats wood like crazy. takes a while to heat up. Need to run wide open with side door cracked to reach 300 to 400 degrees. Basically leave it open to have it hot and burn quickly or cut it back tp make it burn longer but temp falls under 200.Tonight its 25 out and Ive been burning all day got it to 69 in the house.need to reload every 3 hours even with 5 splits and air cut way back. Stove is in a large open floorplan house. Thinking maybe stove is too small to handle temps under 20 degrees. Dont want to run propane.
