Wood was split in summer of 2014
Sounds like your stack is good, maybe even a little on the tall side, this may give too much draw and chew through the wood a little faster than normal
Wood is all oak and other hardwoods
I criss crossed the splits to get plenty of air .( i grew up with fireplaces}
It drafts great creats a tornado of flame that fills the firebox until i cut it back. Glass has been staying cleaner also. Wood must not be fully aged. Right now Im at 275 or so house is 66 degrees, 11 degrees outside.Definitely sounds like wet wood. If that 26' chimney is 6 inch pipe or flex liner all the way, that should draft like a jet. I have no problem maintaining 400 to 500 surface temperatures with a shorter chimney. If you think the tight house might be the problem, crack a window a little and see if the fire burns more briskly. If so, it may be time for an OAK.
I can get it to 400 with door cracked and vent wide open but once I close door and cut back air temp drops to under 300. Dosent matter how much wood is in it.275 isn't hot enough to get usable heat in this weather. Is that with a full load of wood? I generally load up, leave the door cracked till it hits 400, shut the door with air slide all the way open, and finally start shutting the air down in stages when it hits 500. These temperatures are being read with a Condar stovetop thermometer on the rear right corner.
You should be getting above 400 temps for around 4 hours.
how old is your wood ? I am still able to keep the house fairly warm at 65 or so. Its now 9 degrees out. I have a large open floor plan on the first floor. The second floor is warmer.
Not sure of brand of thermometer , wife got it at a fireplace dealer. Its yellow green (ideal) and red. Have it in right rear corner. How many splits do you use to fill the box. Ive never tried really stuffing it. Dont want to damage burn tubes by knocking splits into them. Yes it burns great with door shut and even air partly to mostly closed. Just dosent stay as hot. Im at 300 right now. Seems to burn hotter with ash pan fuller. Should I leave pan full and just sweep out box ?The stuff I'm burning now is all around 20-24 months and I still have wood way too high in MC. The reason for that is because I've got splits that are too large (split the wood for my previous stove). What kind of thermometer, and where do you have it placed? When you shut the door at 400, are the flames still very active? The firebox should be completely engulfed with flames with a full stove at those temps. Last year I had similar problems to yours when I attempted to burn just 18 month Oak. The flames would die off after shutting the door, no matter what temp.
