EbS-P
Did you happen to get a home warranty? I’ve personally not had luck but I know others have.
Evan
Evan
Has anyone seen Jotul doors oval out the thru holes where the door hinge pin goes? I am wondering if I can ream out the 3 holes and but a precision pin to drop in to eliminate the sagging issue assuming no cracks.not that i know of....wishing I had. I have a gut feeling I am going to find a crack tonight
what are you thinking of clamping shut?You might be able to use a pipe clamp or two as temporary stop gap to keep the ash pan door closed and sealed. The ash pan area gets hot but nothing like the top. Ie I would only use all metal clamps. I might feel more comfortable using a very large hose clamp or cable clamping how about those metal band clamp they secure stuff to pallets with.
something Could and would not fall off.
I let ash build up in the firebox compress and then stir it down the grate. Every couple days I could go about two weeks with out emptying the pan.
Try using a shallow, long tray or pan, hold it right under the door and tilt the shovel, sliding the ash off into the bottom of the pan. Much less airborne dust that way, once you get good at it.I could only dream of an ash pan in my insert so I get to be very careful with a shovel and bucket.
I’ve gotten very good with a smaller sized bucket working slowly in the opening of the insert. The draft keeps much of the dust within the fire box.Try using a shallow, long tray or pan, hold it right under the door and tilt the shovel, sliding the ash off into the bottom of the pan. Much less airborne dust that way, once you get good at it.
You da man!UPDATE
I rebuilt my stove over the weekend...5 tubes of stove cement, 1 tube of gasket cement, all new gaskets, new cast bottom and new lower front bottom later it's all back together
You da man!
Gasketed seams on the stove? For the sides, top, bottom or what? Where did you use the stove cement?
Gaskets sound like a better solution to the seams, can't crack and fall out like cement. Any evidence that the gaskets may have been leaking in spots?
