Thanks for your response @jatoxico. I do have a stove thermometer that is placed in the vent. I also have an IR thermometer.
I'm not certain of the species and I'm nearly positive it's not 3 yrs seasoned and may not even be 2 full yrs.
I know there is not a block off plate
In Jøtul defense, every single Insert runs these cheap China fans. Can’t get around them. Don’t forget we’re basically asking for these fans to run 3 to 4 months straight. I’m in New England and I light my stove December 1 and run it till April. And they run in a dirty abrasive environment. For those of you that want to retrofit and have a little creativity, I found a website online called Fireplaceblowersonline.com. They have a FK15 blower for $65. Plus shipping. Exact size. Mounting is different. I bought two of these and was in the process of installing them in the Lopi when I saw the crack. I did run these fans for a short time and their super quiet. Excellent site and thread.
I’ll keep you posted. Dave T.
Hey Soundchasm: Sorry for the late response. yes I think they are. When you go on Fireplaceblowers website they have a drawing of the dimensions. They also added left and right bundled pairs now. The FK15 only comes in Left hand. Good luck. Dave T.
So I installed the insert today and just got the time to fire it up about an hour ago. After about 20 min or so it was throwing some good heat out. I do believe the liner will have to be installed......with air wide open and door cracked it produces a good fire. Soon as that door shuts and seals the flame goes out within a couple minutes. Every time I open the door (air full throttle & slowly open door) I get smoke that comes out.....the wife REALLY X10 hates that part. The guy that I bought it off of mentioned he has a liner so I might be able to get it from him cheaper and install it myself with a block off plate.
Manual said no bigger than 8x12 chimney which mine happens to be just a shade bigger in sq inches......wouldn’t have thought 25 sq inches would’ve been a big deal.
Wood supply isn’t very good in these parts. A cord of oak will cost me at least $300. I bought a cord of pinion and cedar this year for $310. I’m hoping that early this year I’ll take a trip to the nearest forest and buy a firewood permit $15 for a 5 cord max.
Regardless of what you might read, you'll want a mask and gloves when you cut and handle that stuff. Since I have no mechanical skills, I skipped the 24 ga. and only used Roxul.
BTW, there's probably a clearance that needs to be maintained around the stove for air space, and that's so the stove can still cool naturally in case you lose electricity and can't run the fan. It will get *warm* w/o a fan... So in lieu of a specific, don't come into contact with the stove.
Any health problems you’re aware of with roxul aside from resipiratory irritation that I see on the web? A mask is a good idea, agreed.
This is true for sure. Do keep a good inch or so on stove floor though. This is per manual. Like you, I have found the auto fan setting dependent on amount of ash. I switch fan on manual setting once the stovetop then gets to about 400. I switch over to auto after a while so it shuts off in the wee hours of the morning. Measuring temps on this insert is tricky though so I guess you have to do what you’re comfortable with.Hi All, I've been following this thread for a while. Over the past months I've been burning really heavy, I've been shoveling out the ashes, and not paying to much attention to getting all the ashes out. Tonight I spent a few extra minutes with a brush getting out everything from all the nooks and crannies. There was a lot more very fine ash then I realized in the stove. This is the Wow moment - Like others mentioned, the ash insulates the bottom of the stove and the fan's auto feature takes longer to come on. After brushing everything out - the fan came on very very quickly on auto, and wow - tonight the heat output was phenomenal! Every part of the surround was extremely hot, including the left pane (typically my right pane, near the hinges get hotter than the left).
Anyways though I would share my observations - thoroughly cleaning the ashes definitely increase heat output.
Stay warm Rockland friends!
- Tm
