In the meantime I've installed a damper in the flue just above the stove. I considered devising some kind of linkage to operate the damper from the side, but this approach was the simplest, and it has a clean look. Yeah, it was a scary thought to drill a hole right through the face of the cast iron surround. Not going to get but one chance to mess that up! I used a standard cast-iron 6" damper and installed it in the flue just above the top of the stove, below the start of the liner. I had to weld a longer rod onto the one that comes with the damper to extend it out far enough to reach the front of the stove, no big deal there. I threaded the end of it, then drilled and tapped the handle (off-the-shelf at Lowes) to match it, and locked it in place with a jam nut. It wasn't very complicated and it works like a charm. The heat output is substantially improved, and the wood consumption is down by at least a third, maybe more.
![Jotul 550 Rockland Comments Jotul 550 Rockland Comments](https://www.hearth.com/talk/data/attachments/239/239234-d0cb0a95d56753166b33fa437cc14d21.jpg)
![Jotul 550 Rockland Comments Jotul 550 Rockland Comments](https://www.hearth.com/talk/data/attachments/239/239235-53ffde6a465990e0fc17d9386c9d8668.jpg)
