Found this explanation of the failing fridge in cold temperatures
"Actually, most chest freezers will do just fine in freezing ambient temps. Nothing will thaw.
The notorious 'garage problem' is unique to consumer level refrigerator/freezer combinations. Through a feat of engineering genius, IMO, they are able to maintain two boxes (refrigerator and freezer) at two very different, but completely appropriate temperatures (0-ish and 40-ish), using a single compressor and thermostat. The problem is that they only do this well at nominal room temperature. The reason for this is that the thermostat controls only the temp of the refrigerator section. The cold air is directed through the freezer box, and a small amount is allowed to bleed into the fridge. By the time the fridge reaches 40 degrees, the freezer is near enough to zero (in the most common arrangement, the 'fresh food' or similarly labeled knob controls the thermostat, while the 'freezer' knob controls a damper between the two boxes). As the ambient temp drops, the compressor is called upon less and less, resulting in insufficient cooling in the freezer box, and the freezer temp begins to rise. When the ambient temp is below 40, the thermostat is happy and the compressor is never called into service. The result is that the freezer eventually settles in at ambient temp, too.
So, as long as you can live without the freezer compartment, and you have some way to add heat in the winter, an old refrigerator/freezer makes a fine garage kegerator."
And this
"There is a garage kit available for the Kenmore 253 source and Frigidaire top freezer models that will allow the unit to operate in low ambient temperatures of 34 degrees and above. The garage kit is a foil type heater that basically tricks the refrigerator thermostat into thinking the fresh food section needs to be cooled down and brings on the compressor. The other problem is in low temperatures the oil in the compressor will gel and not lubricate the compressor properly leading to premature failure.
If you want to have a refrigerator that will work in the garage Whirlpool makes one called the
Gladiator "
