I've noticed the line between too loose and too tight is very fine when milling.Ya, it’s not just the bark that dulls .Something in the cambium would be my guess. I just wire brush the bark real quick, right where the cut should be if it’s not slipping. Be careful not to run the chain too loose, that’s a quick death blow to an expensive 3/8 bar.
Chain sharpness is even more important for milling. That might explain your heat/oiling issues.It was a busy weekend and I did not get a chance to do as many passes as I wished. Last week stopped by a Stihl dealer and I picked up a second 30* 84 link chain. It was 24.00 and a 10* they wanted 44.00.
On Monday morning before heading back to town I had a bit of time and instead of swapping the chain I decided to sharpen the one that is already on the mill. When bucking rounds you can easily tell the condition of your chain by looking at the chips, not so when milling. I had a feeling the chain was dull since the last pass with it was painfully slow. Using my little gizmo as suggested by @SpaceBus here, i was done within 10min without taking the saw off the mill. I did three passes in a 10’ log in a nice and timely fashion. It was very satisfying.
It looks like 3/4 passes and I need to sharpen. All good.Chain sharpness is even more important for milling. That might explain your heat/oiling issues.
You will get better at it. The Granberg jig works pretty well, but it has some flaws. One such "flaw" is that the flex in the rod/jig will let you polish cutters instead of taking material away, especially if you have the Granberg wax lube. So far I haven't mastered my new Tecomec Super Jolly sharpening rig, but I was getting sharper chains with the Granberg setup.It looks like 3/4 passes and I need to sharpen. All good.
If it’s possible, I’d roll it to the side with a pv and mill like normal. Those live edge are going to suck trying to move.Those 6x6” 10’ posts are heavy!! I think I will need help to stand them up and brace them correctly. Also, my shed will be 10x20 with 2’ overhang on the sides and front. I would like to do a 3’ over hang at the back. My longest log in 12’ so I have a problem. My guy did drop couple of big hemlocks to the side of a hill. Did not bother cutting them down to 10’ - 12’ lengths. They are just there. Access is not easy and they are on the significant downhill slope. I can (with difficulty) cut my 15’ length and slab them to 2” thickness and push them downhill to my milling area. Then somehow cut the live edge and get my 2x6s.
The other option would be to splice the rafters but not sure that would work.
Yeah, that would be bestIf it’s possible, I’d roll it to the side with a pv and mill like normal. Those live edge are going to suck trying to move.
I found I could lay an appliance dolly down flat scoot the slab onto it. Then strap it to the dolly. I could by melyself move an 11’x32”x 1.25” slab.If it’s possible, I’d roll it to the side with a pv and mill like normal. Those live edge are going to suck trying to move.
And of course it would be cheaper to buy the rafters than to pay the excavator guy.Excavator, and they will be filthy with rocks etc
