Thanks for the update. I'm curious about the cool little camper on the trailer. Did you make it? Can you make a posting in the Inglenook about it with some more pictures?
Last question is, do you think the blower fan is absolutely essential? I am not sure if aesthetically i like it... Also, the dealer is talking about finding me one of those radiant heat activated stove top fans, but in reading about how they sit on the stove, I'm wondering how that would work in this situation?
. Yes, get the blower, it will help improve the insert heat output and circulation. You will appreciate this on those sub-zero nights. Skip the stove top fan.
The noise level depends on the stove. Some are fairly well isolated and have a variable speed motor. On low speed these can be quite quiet. Cleaning is important and a good stove will make it reasonably easy to access for this.Still, as a gas fireplace repairman, I found stove mounted fans often noisy, expensive and cooling off the stove too much. And usually hard to clean ----I very often found them so plugged with dust as to be useless, and often very difficult to clean. But my experience with fans on wood inserts is negligible.
The lopi blowers are very easy to clean. The whole assembly is held on with 2 screws and can be blown out with compressed air.
Honestly the majority of wood stove blowers are fairly easy to access.Delighted to hear of a manufacturer who makes this task easy to do.
My, I found LOTS that were buried in the back of gas fireplaces, behind the gas valve and assorted stuff. A big pain for me to do, and not a task homeowners were at all likely to dom on their own.
Perhaps wood stove manufacturers are less likely to burden their customers ----but best to check is my suggestion. Make those sales reps PERFORM!
Hey Fire lovin’ friends,. I love that the chimney runs up the center of the house so hopefully any warm air lost up the chimney will be a warmth added to the rooms above.
It looks great you should be proud of yourself. My wife and daughter love to sleep in our leaving room by the stove. My daughter calls it camping.
Thank you so much! For the most part, the wood is pretty dry! And we gleaned 3 tubs of birch scraps off the ground so that is what I have mainly been using to start my fires.I'm way impressed by what you did. I assume the wood was dry enough since it sounds like you're getting good heat.
