Litesleeper
I have a few Stihl's, a few Echo's, a couple of Husky's and a few Homelites. I've gotten great service out of them all.
I wasn't expecting much from them to be honest and was surprised. Ok power, but I'm pretty sure I could stick tree leaves in them and they would run. It's not a timber saw, I know but it gets my jobs done.Echo 2 strokes are the easiest starters that I have owned.
Yup. My echo is heavy for the power and the gas and oil caps are stupid hard to open without a wide screwdriver or the tool they give you. It's not a pro tool, it's a pro at being reliable and providing simple cutting power. I wouldn't use this if I were a pro, but I love it for what it is. The weed Wacker is commercial quality. It's a tad heavy but I can run it forever and cut down thick thick weeds even with bark on it.I used to own nearly all Echo equipment, including the venerable old 510EVL saw, that I think nearly everyone must've owned at one time or another. They're as reliable as concrete, and nearly as heavy, too.
But that's where my love for them stops. Very poor power to weight ratio, and way too many simple things that they just didn't really seem to put sufficient thought or effort into. Here's one example: On my 510EVL, the gas and oil fillers were tiny screw caps jammed below the chain brake lever, and therefore impossible to even fill without carrying a special funnel with you in the woods.
My Echo saw was under 50cc, but still tipped the scales at 13.2 lb. My 63cc Stihl of similar vintage makes way more power, and weighs only 12.5 lb. Bigger saw, more displacement, more power, less weight... and it has big neck filler caps that can take the nozzle from any gas can or bar oil jug.
Around here, it seems Echo gets a lot of love from landscaping crews, while the dedicated tree services seem to be carrying all Stihl or Husqvarna.
This is pretty much my experience, too. My CS400 started very easily, every time. I liked it for that, and the weight seemed ok. But yeah, all the little things after that I hated. Oil filler cap was a miserable POS, inboard chain sprocket made getting the chain on and off a PITA, and a bunch of little things that ended up with the saw being "abused" out of anger. So far, my Stihl has not seen any of that type of abuse.I used to own nearly all Echo equipment, including the venerable old 510EVL saw, that I think nearly everyone must've owned at one time or another. They're as reliable as concrete, and nearly as heavy, too.
Mine is now battery powered too. I still have my Stihl professional weed eater. It is about 20 yrs old now and has always started, even on old gas. I keep it because it has a pro shoulder harness and handlebars which makes it easier to use for long, springtime cleanups. I just tried out the EGO string trimmer from our Tool Library and was impressed. It munched through tall grass and weeds aggressively. However, the loop handle gets hard on the forearms after about 30 minutes of use. I also tried out the EGO pole saw, but was much less impressed. The chain was wimpy and frequently jumped the bar.My leaf blower is now an ego. No worries of fuel![]()
Yes, it was a single-blade. It came from the Tool Library so I didn't check sharpness. That could have been the issue. FWIW, our gas mower blades are 4 and 5 yrs old. They have been sharpened once.the mower may have had a full blade. I just tackled a bunch of foot tall wet grass with the x bladed ego. I had to go over it twice, but my blades are the original ones, about 2 years of use.
Mine is an 18” bar. Don’t know the CC. The chains in stores are a safety chain, which isn’t as aggressive. I went online and ordered a few “full chisel” chains and it really woke up the beast. It tears through logs like crazy.The Poulan/Craftsman I had was, I think, 42cc and 18” bar. It had a crazy small chain. I can’t remember the file size. It worked great for small stuff.
One thing that still amuses me is remembering my 1970's Homelite Super EZ-Auto, which ran standard 3/8" chain on only 41cc... and never bogged. The saw was not fast by today's standards, but it had serious "grunt" for its tiny displacement.The Poulan/Craftsman I had was, I think, 42cc and 18” bar. It had a crazy small chain. I can’t remember the file size. It worked great for small stuff.
