brenndatomu
Yes, but, the smoke is usually black, not blue...in my experience. Blue smoke sound like typical OWB incomplete combustionCould a dirty chimney Cause smoke with a hot burn?
I couldn't pick out the sizzling sound you mentioned.
But some boilers will 'kettle' in certain conditions. I think it's the way water flows internally in the boiler, or more like doesn't flow in certain spots or cavities or 'dead flow' areas inside. Like eddies in a stream. I don't think I'd describe it as a sizzle, sounds sorta just like you'd imagine boiling would sound inside. Maybe reduced flow from the new pump is now highlighting these spots?
I forget - do you have a bypass loop on the boiler? If not, adding one might help. My old wood/oil unit did, it had another circ in it that would come on at a certain temp (forget the temp now). I think I was told it was there to prevent boiler shock, but it would make more flow through the boiler and maybe stop a kettling condition. If that's what's happening.
Are your return temps always above 140?
The dry crusty stuff is creosote that has started to dry out and burn. It is spaced far enough from the cold walls to get hot enough. I suspect your fire is not hot enough for the area of water jacket that is exposed to the fire, The large area is keeping the fire cold. Is there any way that you can insulate the fire from the jacket with refractory to reduce the number of square feet of surface that is exposed to the fire. I think if you could accomplish that you will see a totally different boiler in the way it burns.
At one time I had a stove that I wrapped with several feet of 3/4 inch tubing for heating water. It drastically changed the way that it burned and did exactly what you are seeing on your unit. I removed the tubing and opted for a "Hilcoil" within the firebox and even with that I could see a difference in the way it burned.
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/174/174249-665a2b0a90824dddcf24af3b9ccc58a3.jpg?hash=k5QuaNDs0q)
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/174/174250-ee022f9c30d13e397c31431f59275433.jpg?hash=cvRAid6ioM)
