whenever you raise the temp setting son the boiler you will get a bit of water that comes out of the overflow tube as water expands when it is heated. Again, this is why i keep a tight differential settings most of the year. set at 175-180 your stove will bubble a bit out the first time gettting up to that temp, but from there on it should stay at the same level as long as you keep her full of good hardwood and dont let the temps drop on you
![[Hearth.com] I'm building a homemade boiler [Hearth.com] I'm building a homemade boiler](https://www.hearth.com/talk/data/attachments/169/169544-c3995ab76000174d050ef216b019314d.jpg?hash=Oov764NWNc)
