I'm not sure if they are still being produced, but they are around at dealers. See what your dealer can find for you.
bogydave said:Like you 20" is the bar length.
I looked at the 346 XP,
BUT::
The only down side for me was the selection of chains available for the .325" pitch.
Loved everything till I got to that.
Choosing between the 359 & 357XP is where I am now.
From what I've read here, the XP series may be more $$ but in the long run just a better built saw for power, handling & ergonomics (& maybe fuel consumption which now-a-days is an issue)
Hard to justify $160 more though.
May just have to cut more wood to justify the better saw.
HittinSteel said:bogydave said:Like you 20" is the bar length.
BUT::
The same selection of chains should be available for .325 and 3/8"
The 359 is a great saw and is basically the same as the 357XP. In my area the 346XP and 359 are very close to the same price and the 357XP is quite a bit more money. I think this makes the 359 the choice for a 20" bar.......unless you can get by with an 18" bar, and then the 346 looks best and would run 3/8" fine if you are against .325
bogydave said:HittinSteel said:bogydave said:Like you 20" is the bar length.
BUT::
I'm not a chain saw guru, so:
What is the difference between chain selections between 3/8 (.375) & .325.
What is the big difference between 325 & 375 for cutting? (kerf?)
Was told by 2 different chain saw dealers that there is less selection in the .325 chain size.
Was also told, (even the Husqvarna guy) that Sthil make the best chains & I could get one made for the 359 or 357 if they carry the good chisel chain in bulk & can make it. But not in .325
Is any of this true??
20" is sooooo much easier on my back, & 20" for the log sizes here is usually big enough for everything.
I really like the weight & $$ of the 346, it was the chain selection issue that took it off of my list. (but barely)
mrfjsf said:Im no saw expert either...How many different chains do you need? There are good enough chains out there for this saw in .325. A full selection of NK, semi and full chisel.
BUT::
HittinSteel said:The 359 is a great saw and is basically the same as the 357XP. In my area the 346XP and 359 are very close to the same price and the 357XP is quite a bit more money. I think this makes the 359 the choice for a 20" bar.......unless you can get by with an 18" bar, and then the 346 looks best and would run 3/8" fine if you are against .325
Battenkiller said:HittinSteel said:The 359 is a great saw and is basically the same as the 357XP. In my area the 346XP and 359 are very close to the same price and the 357XP is quite a bit more money. I think this makes the 359 the choice for a 20" bar.......unless you can get by with an 18" bar, and then the 346 looks best and would run 3/8" fine if you are against .325
Also no expert, but...
9600 RPM on the 357XP vs. 9000 RPM on the 359, 4.4 HP on the 357XP vs. 3.9 HP on the 359. Not the same saw IMO, half a HP is a lot in a small engine. The 346XP produces 3.7 HP and it has much better vibration characteristics than either the 357XP or the 359. It seems to have a very strong following. For $40 more, you only get .2 HP more with the 359 than with the 346XP and you have to carry around an extra pound to get that. Slower chain speed as well. If I needed a bigger saw, I'd definitely spend the extra money and go with the 357XP over the 359. It's a lifetime investment for most of us here.
Of course, I already own one, so I guess I'm forced to defend my gal. ;-)
bogydave said:Actually my wife said buy the one you want. Will probably be the last saw you buy.
That made it more tough, I think that was her plan.![]()
thinkxingu said:Find an MS361 somewhere and probably get a steal of a deal--I got mine for $560 or so with half a dozen bottles of 2-stroke mix, a gallon of bar oil, extra bar, and 2 extra chains. Otherwise, 357xp because the hat adds 1/2 a horsepower.
S
bogydave said:Battenkiller said:HittinSteel said:The 359 is a great saw and is basically the same as the 357XP. In my area the 346XP and 359 are very close to the same price and the 357XP is quite a bit more money. I think this makes the 359 the choice for a 20" bar.......unless you can get by with an 18" bar, and then the 346 looks best and would run 3/8" fine if you are against .325
List is Down to 3
copied to this pg so I could remember specs
346XP 20” 11.2 lbs 3.7 bhp $509
357XP 20” 12.1 lbs 4.4 bhp $709, (+ I get a free Husqvqrna hat )
MS362 20" 13 lbs 4.6 bhp $680
Do I want light weight or more HP??? Machismo in me says "yes", old sore back says "are you sure, think this through".
.7 hp more is quite allot for .9 lbs more. (but for $200 ??)
Weight is an issue, so the Stihls get dropped off the list, I think (362 is a strong saw). (but a future stihl chain is on the list)
Will go look, touch & feel Husky's soon. No 362 in my area to look at.
Leaning to the 357,
If it was a "magnum", sold![]()
TreePointer said:I wanted to run a 16" bar on a NE346XP, so I bought the last one in the shop at the time; and it happened to have a "Husqvarna" narrow kerf (NK) bar with Oregon 95vp chain. That is, both the bar and chain were NK .325" pitch and .050" gauge.
Can you run regular (not NK chain) on an NK bar? YES, and I do. I use .325 pitch Oregon LPX chain and .325 pitch Stihl RSC. The 95vp chain isn't too bad, either.
Essentially all my firewood cutting is with full-chisel chain. Since I prefer to sharpen my chains in a heavy bench vise, I take 3-4 sharpened chains into the field with me every cutting session. If sharpening is needed, I do have a stump vise and hand sharpening kit handy. 16" chain is fairly inexpensive, so try a good chain of each (semi- and full-chisel). As of this posting, a 16" loop of LPX is $12.95 at BaileysOnline.com.
As for gauge, I always recommend going with what local shops stock in our region. For me, that's almost always .050 gauge (and infrequently .063). Also note that, for the same bar length, larger gauges add to bar weight.
