I just moved 2 firebox loads of wood in next to my boiler (6x12 insulated room) from the storage room (10x12 with a tarp door)! I'll get some more in tomorrow.
http://www.tpub.com/content/construction/14279/css/14279_189.htm
A key RULE to remember is that .5 Btu of heat is required to raise 1 pound of ice 1oF when the temperature is below 32°F; and .5 Btu of heat is required to raise 1 pound of steam 1°F above the temperature of 212°F.
LATENT HEAT, or hidden heat, is the term used for the heat absorbed or given off by a substance while it is changing its physical state...To raise the temperature of 1 pound of ice from 0°F to 32°F, you must add 16 Btu. To change the pound of ice at 32°F to a pound of water at 32°F, you add 144 Btu (latent heat of fusion). There is no change in temperature while the ice is melting. After the ice is melted, however, the temperature of the water is raised when more heat is applied. When 180 Btu are added, the water boils. To change a pound of water at 212°F to a pound of steam at 212°F, you must add 970 Btu (latent heat of vaporization). After the water is converted to steam at 212°F, the application of additional heat causes a rise in the temperature of the steam.
