woodhog73
That's just a band-aid for the real issue. You shouldn't have to free rev a saw like that to get oil flow on the chain.
Not really. The saws oiler is low output and fixed. That's one way they get the cost to certain price points. If the OP is running a 20 inch bar on a smaller saw like that, the oiler they fitted with it can't keep up.
It's common knowledge that with homeowner class saws ( not a negative it's a build and price point simply put) certain items are lower quality. The oiler on that saw is one of them. Fit a 16 inch bar on that saw and most likely your dry chain issues will go away. The manufacturer didn't design that saw to have a 20 inch bar buried to the tip and past the tip in very dense wood. Yes it can do it, but if pressed into service all the time for this things like inadequate oiler starts to surface.
And sure they say the saw can run a 20 inch bar and it can. But not very efficiently. But marketing wants to sell as many saws as possible. And they assume the typical buyer for that saw won't be cutting too many 20 inch plus trees, probably just a few and only occasionally.
Case in point. I've got a Jonsered 2252. Sister saw to a Husky 545/550. Pro saw. Adjustable high output oiler. When I first got the saw I didn't check the adjustment on the oiler. It was on ""low" within 5 minutes of bucking a large log using an 18 inch bar my chain dried up badly. Just like the OPs chain. On low my oiler on my 50cc saw same size as the OPs couldn't keep up. Nothing could fix that on low. I turned my adjustable oiler on high and never had a problem since. I've cut 30 inch logs with it using the 18 inch bar and plenty of oil. On low, or probably the middle setting as well, it will dry up.
Also you will find even on big saws such as 660/661 there is even a higher output oiler available if you happen to be say on the west coast felling 60 inch diameter trees all the time. The stock oiler on a Stihl 660 indeed has an upgrade option because it might struggle running a bar big enough for 5 foot around trees.
The whole reason many saws come with adjustable oilers is to help save oil. Most people leave them set to high. But if your making a living with your saw and have to buy your own oil there are times when it makes sense to turn the oiler down a bit. For example If your just limbing 6 inch limbs turn the oiler on low. Save oil. Bucking big logs turn back on high.
Now I've got several saws including big pro saws and I never touch the oilers. In my book the more oil the better. But if I was going to cut 6 inch limbs with my Johnny 2172 or Stihl 661 it would make sense to turn the oiler to low if I cared about saving oil.
![[Hearth.com] Husky 450 chain tightens up during use [Hearth.com] Husky 450 chain tightens up during use](https://www.hearth.com/talk/data/attachments/192/192014-ec5d9101e8fed218029e2b6cfb46d9db.jpg?hash=BmLBeZJcYd)
![[Hearth.com] Husky 450 chain tightens up during use [Hearth.com] Husky 450 chain tightens up during use](https://www.hearth.com/talk/data/attachments/192/192017-d84298de96aa91f31912f91dc3361fbf.jpg?hash=6YBVwTfyCy)
![[Hearth.com] Husky 450 chain tightens up during use [Hearth.com] Husky 450 chain tightens up during use](https://www.hearth.com/talk/data/attachments/192/192178-fd19c92e4853aaa298cce188f6fc2c27.jpg?hash=3CSV-oUqit)
