M
MnDave
Guest
Another thing I do that makes manuevering the splitter with an ATV or UTV real easy is put a hitch ball on the front of the machine.
MnDave
MnDave
All Good ideas!
I also discovered not splitting not quite all the way through is good on redoak, and you look cool throwing the whole log in the truck where it splits into 4 pieces as it hits, or just rip a bit when stacking. Had a few handy 2-3 and 4 "packs" going.
All Good ideas!
Yes normal for the handle to stick in the up position. That is the auto return, allows the ram to retract all the way while you grab the next log to split.I just got this splitter. I haven't put fuel in it yet. The only thing I've done so far is put the handle on. (For some reason, TSC doesn't install that, but rather send you home with it in a bag.) Anyways...after installing it with the engine obviously off, pulling the handle down and releasing it, it returns to neutral position as expected. However, if I push the handle up, it "sticks" in that position. Is this normal? Again, I haven't fueled it up, so this behavior is exhibited while it's off. I've used hydraulic splitters many times, but I've never owned one, so this thread has been quite helpful, but I don't remember the handle "sticking" in the up position before.
So that's auto return. I'm just vaguely recalling an old splitter I used to use for the annual hog killin's. In the vertical position, you'd push the lever down to split the log, then simply let go, and the ram would retract automatically. The only time you would push the lever upward would be to bring the ram up faster.Yes normal for the handle to stick in the up position. That is the auto return, allows the ram to retract all the way while you grab the next log to split...
I think Napa sells the AW32 and AW46.So that's auto return. I'm just vaguely recalling an old splitter I used to use for the annual hog killin's. In the vertical position, you'd push the lever down to split the log, then simply let go, and the ram would retract automatically. The only time you would push the lever upward would be to bring the ram up faster.
Another question (sorry to hijack, but props to the OP for starting the general questions thread specific to the Huskee): I understand I may need to add a little hydraulic oil after a few cycles. Currently it's reading at the upper end of the "OK" range on the dipstick. The manual calls for universal AW 32 or 46, or transmission fluid. The guy at TSC said they just used "regular hydraulic oil". I have some hydraulic oil from Walmart, "Super Tech R&O ANTI-WEAR HYDRAULIC OIL." It claims to be for "general purpose" with applications including "log splitters." However, I can't find "AW 32 or 46" anywhere on the container.
...But I gotta ask...when you kill a hog with a splitter, I assume you go vertical?...
+1 on the work table. My father bought me the one that 33flame sells on eBay. This past Friday I installed it and split 2 cords of wood I have been putting off doing hoping I would get a table for Christmas. It was so nice to not have to bend over all the time. (I do do some vertical splitting too for the really big stuff. My technique needs refining though since I find sitting and bending over does a tune on my back. I keep trying different height seats, but haven't found the perfect one yet.I also recommend getting a work table attachment. They are great backsavers and really speed up larger logs.
Does anyone know the oil drain plug size on the B&S 675E Series motor that came with this splitter? I'm looking to get one of these to make oil changes less messy, but I don't know which one to get. I think it would be narrowed down to the 1/4" or the 3/8".
