Well...
I got a splitter. The associate manager that wanted to be there when I picked the splitter up wasn't there (she told me she worked from 12noon til quitting time...I don't think she told me she was off on Thursday afternoons but...). Anyhow, *everybody* there was super nice and *everybody* knew I had had problems.
The "certified" mechanic came up while I was beginning to look the machine over (I think they called him in while I was at the checkout counter). The engine oil was ok but when I checked the hydraulic fluid it was basically at the bottom of the breather cap...kinda overfull-looking. I noted a little concerned/defensive/angry/fear/panic look streak across the mechanic's face when I noted that but after a moment he pointed out that we were sideways on an incline. We moved the splitter up to a level spot and it helped a bit on reducing the level...but it was still overfilled and I think he was still worried about it...I told him not to worry, that it'd spit it out if it was too much....he offered to take some out. It wasn't long before we had a good banter going and got him smiling. The younger guy was a lot more friendly this go'round, too. There was also a lady clerk that was there most of the time with us kinda overlooking things.
After checking the fluids I told them I had a couple of pieces of wood I wanted to split. I think I startled them a little when I opened the back of the Expedition and grabbed that big big piece of @"(*&$@
elm.
I really think the mechanic got a kick out of it because it had to drop down into granny gear to bust that knarly piece up. The motor loaded up just a tad, the ram slowed down and smashed on through that twisted @&(#&@(&
elm. I did not let off the valve handle and the motor did not bog down as bad as the first one would. This one really seemed to split better. I went ahead and busted that piece up...it was about an 18" that had a nice flare to it from being so close to the stump...it slowed down a few more times but when I had a quarter of a round it would split it with little problem. After finishing that piece up I grabbed a 14" piece of red oak and quickly split it up. No problem.
I feel this splitter is a better splitter than the first one. When I was splitting the @(#&#$*$
elm it did not bog the motor down to the point where I felt like I needed to back off of the valve handle...the first splitter made me back off when splitting rounds of the same tree. After shutting the splitter off I talked with the mechanic some and he said that he had talked with the customer service that I spoke with on the phone. He also talked with Kevin who he said walked him through checking every bolt, nut, screw, etc.,.
After checking it out and getting some feedback from them regarding the preparation of the splitter I went back up front and paid for the splitter. They knocked $100 off, basically 10%, not equal to the manager/employee price or whatever but I appreciate what I got.
I got my receipt and went to the back where I'd left them hooking up the splitter. There was a problem when I got there.
Seems my 2" ball that I have used for the last ten years on the Expedition to pull pontoon boats, john boats, trailers, etc.,. was too big for the Huskee's 2" hitch. :-/
I kid you not. I was about to throw my hands in the air, walk back up front, get a refund and leave but the mechanic was determined to get it fixed. The 2" hitch on the Huskee would only go half the way down on my 2" ball. We tried everything but the ball was too big or the hitch was too small. The mechanic got some 2" hitches off the shelf and they fit the ball....he took the OE hitch off the splitter but then none of the aftermarket hitches fit the Huskee's tongue...either the bolt pattern was wrong or width was wrong. He ended up getting a new 2" ball and trying it in the Huskee hitch...it worked. So, I've got a new 2" ball...it just seems kind of strange that my old ball wouldn't fit. I've got a cheap plastic set of calipers I'm going to use to compare those two balls to each other. We finally got it hooked up and went home.
When I got home I checked the wheel hubs and they were even warm after the 20+ mile ride home....the first splitter had one hub that was warm and the other hub very warm to mildly hot. For some reason I feel that this splitter is a better build and if the mechanic followed Kevin the Speeco rep's instructions I feel that things are put together ok. That ball/hitch thing is kinda strange, but I'll check some of my other hitches out on the ball and see how they do.
continued....
