I have two vertical tanks, because we could not "tip" a single tank due to ceiling height.
They are connected by a "snorkle" tube (purple arrow in photo below) from about 1/3rd down primary to top of secondary. In effect the pair of tanks stratify like a single vertical tank - heat gradient from top of primary to bottom of secondary.
In Summer we turn off the snorkle tube so that we only use the Primary. We only light the boiler occasionally, for the pool (which also has solar heating which is enough 85% of the summer), but we also have solar thermal on the primary store and that definitely cannot heat two tanks! but it keeps the top half of the Primary at 60C / 140F which is enough to heat the domestic hot water (we have a coil at the bottom of the primary to pre-heat the DHW and another at the top for final heat; the bottom coil will do all the work if the Primary is hot enough at the bottom, which prevents destratification, if that is not hot enough then the top coil does the remainder of the work).
