i would get an old rag there so it don't stain your floor
Ohhh, ok. I never noticed that.it not behind the burn pot its the back wall where the ash pan goes, you have to pull the ash pan out of the stove.
Yes. That much I have figured out.Just as a note, the very top most rod is only for cleaning the heat exchanger tubes. Does nothing more than scraps the ash off of them.
One thing is hook the 2 wires to the exhaust blower to you test cord and plug into the wall. It will run at full speed. And clear smoke and maybe draw more
Thank you. I tried that, it didn't blow any differently. But that's something I didn't know how to do before, and I do now!
Yes it has, I've been following this thread. It's great that you and others are intent on getting this stove up and running.good call gfreek its been a long thread.lol
I did. It sounded the same. Maybe a tad slower, if anything.ok before i send that order i want to ck one more thing.. did you hook the exhaust blower up to the test cord and run the stove? does the motor sound faster on the test cord or the same as when its plugged into the harness?
Mine doesnt seem to have one of those. I thought I had looked the inside prettt good and didnt remember anything back there.it not behind the burn pot its the back wall where the ash pan goes, you have to pull the ash pan out of the stove.
Lol. My stove has a dossier.i did smarten up a wee bit and collected all the pics and put them in a file on my pc so i don't have to keep going back to look![]()
A dossier NO just a very long fileMy stove has a dossier.
Ssyko.Rick? Sidecar? if we get this burning. can we burn the residue out of this stove? I have never dealt with corn residue. but this stove is gonna run one way or another
The much newer units they put access covers to get to the hidden passagesMine doesnt seem to have one of those. I thought I had looked the inside prettt good and didnt remember anything back there.
Ssyko.
First off I would not buy a Conv. fan at this point. That is the least of your worries. There is a major restriction in the stove where there is no access. Between the heat exchanger and the comb. fan.
This is how I think it played out: previous owner ran the stove without proper cleaning until the point that it was so restricted that the vac switch would not close. Then thought must be a bad switch, stove looks clean to me. Replaced the switch and same issue, it would not close. At this point he should have called for service or hopped on this forum for advice. As we know the vac switch is there for a reason. If he would have brushed out the ash traps and sucked the stove out with a leaf blower it would have can back to like new airflow, at that point the blockages would have been just loose fly ash.Instead he jumped the switch, got the unit to fire in a starved for air situation and ran it like that. Burning rich for a extended period of time and turned blocked passages into a hardened mess. Then it got to the point to where it is at now and will not burn do to severe blockages that he pulled it out and unloaded it. If Rx wants to try to salvage it and try to burn it out, I definitely would not suggest doing it in the house. Burning creosote is a stinky mess and if it shuts down and spills smoke in the house or worse it could be bad. I would take it outside and force burn it using the hair dryer to boost airflow to heat it up.
It would be worth a try. It just worries me doing it inside the house. I would take it outside and let it rip. As we know, the vac switch is designed to shut the stove down prior to it getting to the filling the stove with creosote point. It would be like running a engine 50k mileds until it was tarred up beyond belief then trying to resurect it. Trying to burn it out is the only option, other than that, it would be to scrap it? That is why I suggested not worrying about a squeaky Dist. blower for nowi agree 100%, I have a combustion blower i know is much more powerful than the original and she would not need a hair dryer. My concern is weather the stove it is recoverable at all. My thoughts were to get 1 of those creosote logs, break it into chunks that would fit in the pot. All safeties jumped with the blower i have or hair dryer run it to an almost over-fire hand feeding chunks till it opens up or burns out the blockage. Do you think this would work?
The pic of creosote dripping out of the pipe is not a good sign. Are the exhaust paths so hidden that there is no way to clean the hardened creosote on this unit ? Agree at this point the idea, if possible, to move it outside and turbo fire it to burn it out.. & is there a chance the creosote can ignite like a chimney fire ?
That is what I am afraid of doing this indoors.The pic of creosote dripping out of the pipe is not a good sign. Are the exhaust paths so hidden that there is no way to clean the hardened creosote on this unit ? Agree at this point the idea, if possible, to move it outside and turbo fire it to burn it out.. & is there a chance the creosote can ignite like a chimney fire ?
