Sorry, that was poor context.You just lift the grate out and drop a new one in I believe
I was referring to replacing the catalytic converter. Is that a difficult procedure in most cases. At $332 I wouldn’t want to risk it for nothing.
Man I got 50% of people (locals who have been burning for years) who say use it anyhow(the liner). And then a bunch of you on here saying not to use it. I know why people are saying not to use it but the holes were so darn tiny, I have trouble seeing the risk for a fire or two?I believe it is not legal to run a cat stove without the cat. When the cat is there, but not working, that's a grey area...
However, if the cat is not working, you should not choke down the fire much, because if you do choke it down you'll have a creosote factory on your hands (that the cat is not cleaning up). I.e. with a non-working cat, one should run it hot enough in view of what you may be pumping into your chimney.
Regardless, I would not light up if your liner has holes in it.
As an educator though I know to listen to what I'm being told. I don't want to burn my house down but I also want to use a stove this year and see no way to do it financially unless I use the current liner and repair the current stove....maybe that's just not an option.
Totally get it and appreciate what you're saying. Additionally I can say I'm probably more seeking an answer that fits what I want to hear...which isn't how to go about this.You have trouble seeing the risk. In the end you came here for advice, suggesting that what "locals" say does not carry sufficient weight for you.
Risk and safety are not issues that are decided by some majority vote.
As a dad though, I know there are things I will not take risks on, in particular if I am not able to actually quantify the risk (a chance of 1 in 10,000 that you put your house on fire?). "darn tiny" is not good enough for me when an expert (and @bholler is one) suggests this is not safe and it is not just me on the line.
So, you can follow the crowd, or follow advice from an expert, that was given after you deemed it necessary to solicit said advice.
I do feel for cases where one needs to do something but financially it is not possible. I've seen too many situations like that. No criticism from me there. Life happens. So I get the conundrum - but then I cycle back to "As a dad...".
If this was the case of a seasoned wood burner, familiar with burning in many different types of stoves including cat stoves, then a cautious experiment might be ok. However, in this circumstance, it would be foolhardy and potentially dangerous. There is a learning curve ahead, even if the stove was new and the wood was perfectly dry. With a dubious condition liner and a neglected, complicated stove, this could get out of hand quickly. At a minimum the insert needs a full $50 gasket kit and a $200 catalyst for starters. This presumes that all of the multiple parts in the stove are true and not warped or cracked. If they are warped, this can easily end up being a financial can of worms or a waste of money.Man I got 50% of people (locals who have been burning for years) who say use it anyhow(the liner). And then a bunch of you on here saying not to use it. I know why people are saying not to use it but the holes were so darn tiny, I have trouble seeing the risk for a fire or two?
While I'm not a Dad yet, I will be in the not so distant future and I don't want to endanger my family or home.
I guess letting it sit is the best and safest action. We have a pellet boiler so heat isn't an issue but for Power Outages and Cold Snaps....would be nice to have.
Ah well.
Well not quite yet. Obviously planning these things doesn't always go smoothly, however, we are going to start trying soon! My wife and I are both Elementary Educators so we sort of already have children, haha.and congrats on what I understand to be a little one on the way! It'll be a ride![]()
Would it be bad practice to pull the insert and just have a 6" liner dropped down and just leave it until we can find an affordable stove or something used locally? We are considering a freestanding stove (much more used ones in our area) to put in the hearth. Of course it seems there's a ton of measurements I need to assure safe clearances first...which will be easier without the insert in there.
Just trying to get ahead of the game and start shopping even if we can't afford everything now...do what we can.
oops. Well, good luck.Well not quite yet. Obviously planning these things doesn't always go smoothly, however, we are going to start trying soon! My wife and I are both Elementary Educators so we sort of already have children, haha.
Yes, that sounds reasonable. You might even be able to sell the old insert for $100-200 to someone wanting it for parts. Also, start collecting, splitting and stacking firewood. Most hardwood takes 1-2 yrs to season properly.Would it be bad practice to pull the insert and just have a 6" liner dropped down and just leave it until we can find an affordable stove or something used locally? We are considering a freestanding stove (much more used ones in our area) to put in the hearth. Of course it seems there's a ton of measurements I need to assure safe clearances first...which will be easier without the insert in there.
so the insert I got from Costco comes with a liner. New Liners are easy to get. I guess I don’t see a reason that just leaving a new 6” liner hanging by the top plate is better than no liner. Maybe pellet stove comes up for sale? They can run quite awhile on a battery or small generator. And you all ready have pellets. My dad installed. An outlet that just runs right outside that he can plug his generator into. It was fast to do. It doesn’t have any connections to any other circuit and is dead until he hills it up to the generator. I’d clear everything out and seal the chimney with a chimney ballon for now.Would it be bad practice to pull the insert and just have a 6" liner dropped down and just leave it until we can find an affordable stove or something used locally?
That's actually the route I originally wanted to take; however, I'm afraid of heights and would rather not go on my roof...purely out of fear haha. I am more than mechanically capable to do the job...I think. Just hate heights.so the insert I got from Costco comes with a liner. New Liners are easy to get. I guess I don’t see a reason that just leaving a new 6” liner hanging by the top plate is better than no liner. Maybe pellet stove comes up for sale? They can run quite awhile on a battery or small generator. And you all ready have pellets. My dad installed. An outlet that just runs right outside that he can plug his generator into. It was fast to do. It doesn’t have any connections to any other circuit and is dead until he hills it up to the generator. I’d clear everything out and seal the chimney with a chimney ballon for now.
I’ll measure! I assume you mean from the floor of the hearth to the top of the chimney.How tall is the chimney on this insert? If you can afford the Costco kit, then it probably would be another $5-900 to have the liner installed. This should come in well below $3000. Before ordering, the fireplace should be measured to make sure there are no issues with fitting.
That's correct.I’ll measure! I assume you mean from the floor of the hearth to the top of the chimney.
Are most sweeps willing to install a customer purchased liner?
Definitely will do. We have two local well reputed sweeps that we use; I’ll have to check in.That's correct.
It depends, call around and ask. Sweeps are getting very busy now.
Yes very busy. And we get 2 or 3 calls a day if we can do a liner or install before the heating season.That's correct.
It's the grasshopper and the ant story. Many people don't think about cooler weather until it gets cooler.Yes very busy. And we get 2 or 3 calls a day if we can do a liner or install before the heating season.
Why don't people think of this at the end of the heating season?
And they get mad when we say we can do it on a Saturday but it will cost more.It's the grasshopper and the ant story. Many people don't think about cooler weather until it gets cooler.
