Thanks
@EbS-P . All I can get from home is the abstract, I will see if I can open that from inside my work network Tuesday.
I am building a new P box for home use, should have it up and running in a week or so.
The original in post one this thread exceeded expectations. I had excellent air quality all through my heating season, except our indoor AQ dropped to good while we were cooking in the kitchen, same as
@ABMax24 found .
There are two issues I am addressing with the second build.
1. With filters on left, right and rear, the original P box cannot be shoved up against a wall without blocking off one of the filters. To address this, I am putting the new build on casters to lift it up off the floor. I will be able to mount one filter element in the bottom, and place a blank panel on one of the sides, so Pb2 can be shoved against a wall.
2. Our cat spent a great deal of the winter sleeping on top of Pbox1. The cardboard top secured with duct tape made it through the heating season, but the tape was needing to be firmly pushed back down every 2-3 days as pollen season was spooling up. So I am making Pb2 out of plywood. My cunning plan is to put a cat bed up there. She will either knock it off and sleep on the bare plywood, or go somewhere else to nap.
At this juncture I explicitly reiterate all you need for excellent IAQ is a box fan, the box the fan came in, 3 MERV13 filters at 20x20x1 inch, some duct tape and a sharp knife. And dry wood and no draft problems, but let us not skid off into the weeds. As pictured in post one, you can use the box fan to establish a convective loop in your home and clean your air at the same time.
An alternative, if you have a big enough box from Amazon, would be to make top, bottom and one side from cardboard and only buy two furnace filters. Between wintertime wood stove, spring pollen and summer wildfire smoke I get about one year and have to replace three filters. Two filters should work, just not last as long. Or you could set two filters behind the fan to make a triangle and then cut a triangular top and bottom from the box the fan came in.
I am building Pb2 from plywood so in the future all I have to do is replace the filters annually, not rebuild from scratch every year.
I am putting in a baffle between the filter box and the fan intake, and I beveled the filter side of the baffle with a quarter inch roundover router bit. This is NOT necessary for excellent indoor AQ. It is a thing I am doing while I am starting with a fresh sheet of plywood that should make the finished item incrementally more efficient. I doubt I will find a measurable increase in performance, but this should last 20 years and it would bug me to not do it.
![[Hearth.com] Homemade air filters - Good indoor air quality, cheap [Hearth.com] Homemade air filters - Good indoor air quality, cheap](https://www.hearth.com/talk/data/attachments/296/296774-4a3b94c05ef417e5526c661d49d61701.jpg?hash=C6Xmbr-8l2)
