@woodgeek , you clearly know way more about HVAC systems than me. I am simply not equipped to even attempt a peer to peer discussion with you, because I don't have the background to be considered your peer by any reasonable standard. Thank you for sharing your perspective.
I don't have any duct work in my home, except for the courtesy fan in each bathroom.
My wife's office does have forced air, and some mold in the ductwork. There is no visible labeling regarding MERV rating or pressure drop that I could find anywhere on the system near the filter. I did find three new filters in the furnace closet, so replaced the filter that had been in use for 6-7 months. Filter size is nominal 15x30x2, no printed MERV rating but visually less than MERV13. Building is more than ten years old.
Right now I have another $700 worth of particle counters inbound. When they get here I am going to have to run them a while all on the same table to see how close they read to each other, then I can start taping them to the walls in my hallway to see where the PM2.5 goes between leaving the open loading door of the stove and arriving at the filter array.
Once that is done I can rent a PID or FID VOC detector and go looking for VOCs in my house.
I share your dismay at the expensive room size air cleaners. They are expensive up front and often use expensive proprietary shaped filter media. I have two of them retired in my garage. Both were noisy, as team the both of them could not keep up with my 1200sqft home, and I was able to get three furnace filters cheaper than I could have replaced the filters in those two units.
I did build a somewhat prettier unit for my wife's office building. She only has room for it in her office in a corner during the day. After hours she pushes it out into the hallway and runs it on high overnight. Filters on two sides and the bottom, weatherstripping under the fan for sealing. If someone wanted to they could go bananas with birdseye maple, a french rub finish and maybe some speaker cloth over the filter media to make it look like a big subwoofer. I used baltic birch plywood, spray shellac and got the item into service.
My immediate goal is cheap, simple to make and effective. Make pretty is not on my current list of things to do.
![[Hearth.com] Homemade air filters - Good indoor air quality, cheap [Hearth.com] Homemade air filters - Good indoor air quality, cheap](https://www.hearth.com/talk/data/attachments/284/284949-202816a2041ef94d8ea831e5b763b7bb.jpg?hash=CYBqJ5QJ41)
![[Hearth.com] Homemade air filters - Good indoor air quality, cheap [Hearth.com] Homemade air filters - Good indoor air quality, cheap](https://www.hearth.com/talk/data/attachments/285/285133-1a863e037a2932f7f678259b03c7a562.jpg?hash=sBi5FMNAme)
