Help with storage plumbing
Any other advice for me on the new drawing in post 53?
...just a couple quick notes. You only need to connect your expansion tank to one point in the system (assuming you are using a conventional bladder type expansion tank). Also, although delta-T pumps are excellent, the pump in your design seems to be redundant. If you choose to keep it you will need to make sure that it only switches on during a call for heat.
I would also avoid vertical piping into your buffer tanks. Even with some kind of flow diffuser you may find it detrimental to thermal stratification in the tanks.
Just some general advice. I hope it helps.
I'm not seeing the pump redundancy?
There may be times where you would be heating storage from boiler and the loads weren't calling for heat, and there may be times the loads are calling for heat & your boiler isn't moving heat.
I'm currently redoing my drawing and have a quick question. Referencing my latest drawing, should my "HX to storage" loop be on its own manifold or will a single set of manifolds on my tanks be ok to charge storage and run to heat loads?
