leon
If your determined to make the expansion tank yourself I would be sure to follow the B+G
recommendations for the one inch airtrol valve. IT has to be connected to the bottom tapping in
the tank as illustrated in the tank examples AND the water level in the tank cannot exceed 2/3's
of the horizontal height of the tank as discussed in the drawings and sizing chart.
For the amount of water you have or propose to have in storage you need the next larger airtrol valve being one inch
and a 30 gallon tank AT LEAST for the water volume as you must have a one inch common header pipe that
comes off the tow storage tanks and will be connected to the 45 degree riser that attaches to the one inch airtrol fitting in the horizontal tanks tapping. You can use unions for these connections with no issues.
This is why I suggested the 30 gallon B+G tank and the one inch airtrol for your installation as they are pressure and leak tested and it will work right out of the box with the 1" airtrol fitting. The only thing you need are reducing bushings, pipe strap, pipe plugs and you have to decide if you want the water glass gauge which is a must when filling the system as you will know how much water is in your system if you want to check it as the airtrol valve has no restrictions to flow
![[Hearth.com] Help with storage plumbing [Hearth.com] Help with storage plumbing](https://www.hearth.com/talk/data/attachments/176/176605-53c2586deb866ed3564482042b39bd8a.jpg?hash=JksZlRmDFB)
![[Hearth.com] Help with storage plumbing [Hearth.com] Help with storage plumbing](https://www.hearth.com/talk/data/attachments/176/176775-c83f6cbdcaf32f168f979137a0b04171.jpg?hash=qoQ493w832)
