Hmmm, I don't know. My stove is fairly tight, I believe, but when it's running hot, it makes a pretty big sucking sound. If I listen close, I can hear it from the next room.
My side door isn't tight at all. The $5 bill slides super easy in some spotsHmmm, I don't know. My stove is fairly tight, I believe, but when it's running hot, it makes a pretty big sucking sound. If I listen close, I can hear it from the next room.
Try taking an incense stick or something like that and poke around the door to see any air draft.My side door isn't tight at all. The $5 bill slides super easy in some spots
Then you will need one of these installed. It is the last fitting and connects to the stove.But get the gaskets checked and replaced too. Both issues are combining to cause the control problem.we are a double wall.
All the gaskets on the stove are brand new and professionally installed last thursday (Dec 12!!) The front door has a tight seal, but the side door doesn't. I took a video but it's .mov so I can't load the video to here.Then you will need one of these installed. It is the last fitting and connects to the stove.But get the gaskets checked and replaced too. Both issues are combining to cause the control problem.
http://www.amazon.com/Simpson-Duravent-8679-Double-Section/dp/B003JV7X02
ALL gaskets were new this past thursday Dec 12 and professionally installedSounds like time for a replacement gasketing.
I will try to post to youtube. The dollar bill test is loose on most places. The exception being top left corner of the side door. Not much is needed to pull the bill through. I wouldn't say the fire was any stronger to one side.Sounds like the side door gasket install is not right. It could be an undersized gasket was installed. The door needs to seal tightly when latched. How loose is the dollar bill test on the side door. Is there any tension required to pull it out? Is it loose at most all points around the side door? Is the fire now much stronger on the left side of the stove?
Maybe post the video to YouTube and provide a link?
LOL. Glad you said it first. Maybe it was a bad joke, but I was going to suggest a $10 bill, so I appreciate bad jokes, since I do it all the time.Maybe the $5 bills are thinner than $1 bills. Sorry, bad joke.
Thanks, that was a really helpful suggestion. I am not sure it's what the problem is but is very good to know. We are still waiting for the stove company to come out and fix the gaskets, but it is Christmas so I guess they are taking some well earned time off.As others have said definitely replace any non-tight gaskets with larger ones, do a smoke test and if everything is tight and it's still running too hot try the key damper.
One other thing to consider, especially because your stove is older like mine, is that it is possible to slide the air control lever too far to the left and if this happens it has the same effect as the air being about half open. This has happened to me and at least one other forum member that I know of. To make sure this isn't your problem, when closing the air down all the way, just gently tap the lever with your finger in small increments until you feel a positive stop. If you push it too hard too fast it might go too far and allow a lot of air in but you won't suspect this as the problem.
