Help. Can’t snuff my BK
Smolder
Burning Hunk
Dec 25, 2019
124
Ashton, Ontario
Hi,
I have had a BK Ashford 30 for 5 years. Great stove, no issues, clean the chimney one a year and it’s never overly crusty. Runs 24/7
My actual furnace is broken, it’s below freezing and it’s an old home without insulation.
I ran some “wet” wood for a few weeks and when I went to light it up last night (it burned the last load and I was at work), it was hard to start.
When it finally lit off on the coals the house started filling with smoke, it has actually been hard to get logs into it without it letting some smoke into the room lately. Anyways, smoke coming out of stove pipe seams, some coming out the chimney, but lots just spilling out the air intake and seams.
I turned the air down to off (12 o’clock) 9 hours ago and it is still between active and cold. Still very warm to touch.
It won’t stop, still stinks just not smokey.
I need to kill it so I can clean the chimney before things freeze up in here. My only thought at this point is to bring a wheelbarrow into my home and throw the chard smoldering logs into it and dump them into the snow. I have welding gloves.
Apparently the damper all the way shut isn’t actually all the way shut.
Any help please.
Reactions: GG Woody
Cap problem most likely. There was another post very similar to this a few days ago. Plugged cap. As far as removing the logs I’d not do them without misting them with some water first. Steam them up, close the door, repeat. Water expands 1700 times its original size so it should snuff the fire pretty fast. Empty out a spray bottle from cleaning solution and use that..
Reactions: Smolder
I wouldn't recommend hot steam with a catalytic stove unless you have another cat to replace it with and gasket.
Just need to open the bypass.
Could be the cap, just went out and checked it again, some smoke/steam coming out of it still, but not much. I can actually clean the main flue from outside.
  • [Hearth.com] Help. Can’t snuff my BK
Can you get up there and remove it?
That’s the best scenario.
This is the naughty stove. I am thinking the cap is the culprit, smoke was coming out of pipe seams even at the thimble so the pipe was probably full of smoke and it isn’t a blockage low down.
Reactions: GG Woody
Yea for sure man check out this thread
Reactions: Smolder
Cat could still be hot and while having the bypass open does allow a good majority of smoke to go up the chimney you still have draft going through the cat that could suck those water droplets up and once it hits a hot/warm cat it could cause thermal shock.
Use sand, cover everything. It may stay hot under but it'll stop smoking if using enough sand.
Be aware though that CO might still come out for a while when burying coals.
Then clean what needs cleaning. Sooteater from inside rather than going up 43'?
Just open the air up and let it burn out. Or pull out the wood which sucks
It appears there is a lack of draft after burning wet wood.
So burning it down may not be possible.
He said the CAT is still active and it's not smoking. I think it will burn
Yes. But cat thermometers are sometimes improperly calibrated.
And he said this
"When it finally lit off on the coals the house started filling with smoke, it has actually been hard to get logs into it without it letting some smoke into the room lately. Anyways, smoke coming out of stove pipe seams, some coming out the chimney, but lots just spilling out the air intake and seams."
And that was on a hot reload with coals, so less likely to be reverse draft (though not impossible).
If the cap can be accessed and removed, I'd consider not putting off cleaning it and the flue, doing this asap while there is still daylight. If that requires taking the charred wood out then so be it. Be careful on that roof. Run some electric space heaters in the house in the interim.
Hope there are good smoke and CO alarms in the house. Try to get some fully seasoned or kiln dried wood, or high-quality, compressed brick or log fuel.
