Dirty glass may indicate burning too low of tamps and not dry enough wood.4barrell, I feel your pain. I am getting the same poor results with my lopi freedom. Maximum of three to four hour burn times with a load of quality wood. I think they let too much air into the stove with the damper closed plus I do have a strong draft. Also, I get dirty glass almost after every burn cycle. Setting the alarm once, more often twice getting up to reload sucks big time. I say dump the lopi and don't look back.
I have a Avalon Olympic right now, house is about 1600 sq ft. with no wall insulation( hope to take care of that soon). This stove works good, lots of heat, great convection system, but I cannot get more than a four hour burn. Checked for leaks and all. The short burn times are becoming irratating. I use hardwood, seasoned one and a half to two year dried.
Any bricklayers out there, is it possible to increase the size of a existing fireplace.
Do you have an old home? Is that a Rumford fireplace?Weatherguy, I wish I could. The main problem I have is the depth of the fireplace is to shallow, only about 14 inches.I live in MA like you.
He's setting the alarm to wake up and reload.....Dirty glass may indicate burning too low of tamps and not dry enough wood.
If we all only got some dollars for everyone that is so certain their wood is quality, when it really is not.
Setting off alarms is truly not good, and downright dangerous.
Of course it is possible. Is it worth the cost? I removed the masonry fireplace and chimney in my home to install a regular freestanding stove and vertical flue. Any work on a fireplace is polishing a turd.
Hopefully someone is still reading this thread. I am confused about cats being able to go low and slow and non-cats hard to slow down. The dealers I have visited have said that if you want to slow the fire down ( in a non-cat) you just put in less wood or close the air more. Is that not true? I currently have a very old cat stove and have been worrying that it would be hard to switch as I am know how to manage it pretty well,A non-cat stove doesn't put out more heat. If the stoves are equally sized the output will be nearly the same. The difference comes when the air is turned down to low. The cat stoves will cruise low and slow, non-cat stoves are hard to slow down once they get cruising and. The Super27 is a good stove with burn times of 8-12 hours. The BK is gonna give you consistent 18-24 hour burns.
It's a matter of degree, but if the dealers are leading you to believe that you can close down a non-cat like your cat stove, that is not true. Below a certain point, you can't "close the air more" on a non-cat stove, if not for technical reasons, then because the EPA says you can't.. . .I am confused about cats being able to go low and slow and non-cats hard to slow down. The dealers I have visited have said that if you want to slow the fire down (in a non-cat) you just put in less wood or close the air more. Is that not true?
I have a PE Alderlea T-5 with the exact same firebox and I get 10-12 hr. burns all the time.. I only expected and sought to get 8 hr. burns so I was pleasantly surprised with the longer burns. I live in SE Mass. and heat about the same size home as you.Hogwildz, believe me I have tried it all, north south,east west. big splits small splits, you name it, the results are always the same. What I meant originally was I always thought that while cats burned longer, they don't put out as much heat as a non cat. Anyway. for all you Pacific energy owners, how long of a burn are you getting from you're super 27 and summit with useful heat say 350 degrees and over.
That article is way too technical for me. Besides the Woodstocks and Majestics, what other good cat stoves are on the market (Blaze King is out of the questions--no dealers anywhere near me)It's a matter of degree, but if the dealers are leading you to believe that you can close down a non-cat like your cat stove, that is not true. Below a certain point, you can't "close the air more" on a non-cat stove, if not for technical reasons, then because the EPA says you can't.
http://www.gulland.ca/florida_bungalow_syndrome.htm
I just purchased a Buck 91 cat have yet to find any bad reviews on them ....might look to see if any dealers in your area.That article is way too technical for me. Besides the Woodstocks and Majestics, what other good cat stoves are on the market (Blaze King is out of the questions--no dealers anywhere near me)
Ray
Another brand!! They seem to be unending. According to the Buck website the dealer around here is a place I was planning on visiting Thurs--not too far from me.I just purchased a Buck 91 cat have yet to find any bad reviews on them ....might look to see if any dealers in your area.
Honestly I don't look at stovetop temp what I get is a warm stove with blower still running and plenty of coals for relight.. This stove is rated over 80% efficient and the burn times agree with this. I consider this good for any 2 cu. ft. stove..You're getting burn times in the 10-12 hour range with a stove top of 350+ 12 hour in? That's pretty good!
Ray
