I'm all for that!A second stove of any type for more heat could help alot to get off those fossil fuels.![]()
Your insert is too small to live up to your expectations and undersized for your climate and square footage, no matter how well seasoned your wood is. Take the Superior offer and upsize - you'll be much happier.
A bigger stove, drier wood and a block off plate (if you don't have one) would probably solve problems.
If the dealer is offering you a bigger stove for just the price difference, jump on it. This is a long term investment and will pay off down the line.
+1. . .I would go bigger. AND do the stuff jatoxico just mentioned while installing.
The lil Winterport insert firebox is only like 1.2 or 1.4 cubic feet of space. Good for heating a thousand square feet or so and maybe four or five hour burns.
Trade in while you can.. . . Superior Hearth's solution?? Buy a bigger stove for an additional $800.00.
Has anyone a suggestion for me?
I agree......if he burned through 100's of dollars of bio bricks, it should have been kicking the heat out.Missed the part about the Bio Bricks. With those, you should have had some heat, barring crappy house layout / flow, and other hinderences. A smaller fire box is not going to help with the nasty winter we've had.
Wow..... Where do we start.... You need to answer alot of questions in order to get help and a few pics of the room would help......you may need to upgrade to the biggest insert possible, 1 size up won't cut it.....
What type of wood are you burning?
How long has it been split and stacked? What is the MC?
Do you run your stove fully open?
How much wood do you burn at a time?
At what speed do you run your fan?
How cold is it outside?
How many windows do you have? Are they single pane?
What's your insulation like?
How big of a space are you trying to heat?
Are you burning 24/7 or do you cold start everyday?
tank#2 of oil......how is your hot water heated?
I know this has been asked but I did not see the answer.?
, I had to run that thing above 650 to even keep the basement above 65 it might of heat 1.4K if I ran that thing till it glowed red.  When buying a stove always take what they say it heats with a gain of salt.  Go for a stove that heats a bigger area than you will be heating.  A stove that heats between 1.8 - 2K would have been a better choice. My mistake of going to small cost me around $600.  But, since all the piping is in place you might be able to make a deal with your dealer to get a larger stove at a discount since your dealer should have told you that the stove would have an issue fitting your needs....He said the wood was a bit damp ( though it burns fine in our other fireplace ) and we weren't getting the stove hot enough. ..
This is a great point........I find closing my basement door and doors to rooms that I do not heat with the insert helps quite a bit in heating up the room......why? Because it stops the cold draft from coming into the room being heated. We were sitting on the couch in front of the insert, we could feel a draft on our necks, I said this is impossible, sure enough, closed the doors and the chilly necks disappeared.....Can't believe no one else has mentioned this (I think). You have an open fireplace that you're trying to heat the house with, too? That's got to be sucking a ton of heat out of the house as well.
I know everyone else has already said this, but if your wood is not fully dry, you're really strangling what the stove can do.
having another fireplace is probably sucking out whatever heat you are creating
It's not just that an unused fireplace can suck heat up the flue. I was amazed the interior rear brick wall of my unused fireplace typically measured 32 degrees during this winter, and that was with a well insulated block off plate replacing the damper. The outdoor cold conducted through the exterior chimney brick directly into the rear wall of the fireplace. It's a MAJOR source of cold into a house that I don't hear mentioned very often.
A beer says the installer did not insulate the damper, 2 says there ain't no block off plate.
Wendy is this an exterior chimney? If you have a small cape the insert may be enough to heat the first floor if you make sure the heat gets into the room and is not going up the chimney and if you burn good fuel. First year is not uncommon to have wet wood. Ask your installer to stuff the damper area with Roxul insulation or you can do it yourself for $40-50.
Lots of good points above, but I would say...
You are not the only first time insert user to have this problem....we get one a week in here. You are making oodles of heat (cuz there is just ash afterwards), but it simply not getting into your conditioned space. You need to figure out where it is going and fix it. Choices are:
1) up the flue inside the liner (because YOU are giving it too much air, which carries the heat up the stack)
2) up the flue outdside the liner (because the INSTALLER didn't seal the top plate on the chimney or the block off plate)
3) out the walls of the chimney (because exterior masonry chimneys suck heat to the great outdoors)
or some/all of the above.
Solutions are:
1) try closing the air down after you have a good fire going with dry wood or bricks, heat should jump up and you should get 'secondaries', and burn can get longer.
2) ask installer if top plate sealed and block off plate installed...send someone on roof to inspect, look behind surround, post pictures here.
3) if chimney is exterior, make sure damper area is either blocked with a metal plate or roxul batt insulation, AND line the masonry firebox with roxul batts between the insert and bricks.
2.2cuft firebox on a 1,300-1,400 sqft home for me. Most the time I have the two upstairs bedrooms closed off making it closer to a 1,000 sqft ranch.We heat our fairly well insulated 1500sf home in WV with a 2.1cf stove rated for "up to" 2,000sf and it struggles when temps drop to near or below 0f
