Welcome aboard ovendoctor.
How are ashes handled in the Harmon and how often do you have to clean the flue tubes?
Wecome Doc,welp the cleaning job was not too bad[need to purchase a 2''boiler tube brush]
also a retractable drop lite would be wonderfull
the secondary tubes are going to be a pain due to having to remove the heat deflectors in the burn chamber to axcess the ash trap
figure ill get a smaller dia. vacuum hose and go at it from the top
was just able to get the 2'' hose down the tubes this time to clean the ash traps
over all its still easier than the Breckwells [parlor stove and Big E]
had the fuel feed on 1 today for the DHW and it worked great
now for the sad news
I read the thread for running lines under ground [what a nightmare]
I really would like to run a line set out to the green house/sauna house
its about 30' but the water table is at ground level here
so Iz really have to do some heavy thinking on this one
the whole idea is to have it all automated so there is less work growing food in the winter up here
its great picking fresh produce Christmas day with 6' of snow on the ground
more updates to come
Doc.
I have a Hydroflex 60 and have been using it for the past year. My issue is with cleaning the heat exchange. Seems ash always gets distributed through my basement. I'm using an ash vacuum which definitely cuts down on the ash circulation but I'm still seeing a considerable amount. Any suggestions or tips on the weekly cleaning?
I also noticed a gooey discharge coming from just above the burnpot door after getting it up and running for the first time this season. I've asked my Harman dealer about it, he said he would send my picture to Harman but I still haven't heard back from him (they are the most reliable).
Thanks!
Hello Thro9,
My HF60 certainly creates some dust and ash in my utility room during cleaning, but nothing like cleaning my woodstove in the adjacent room, which is much worse. Using an Ash Vac should give you the best results, but beyond that, I have no suggestions on cleanings. I have been burning my HF60 about 3-4wks now in 2013, but have not clean it yet. I have really good pellets this year (very low ash).
I also noticed a gooey discharge on my HF60 frame around the lower ash door the first year I fired it, just like you are describing above. I had assumed I was pulling to much heat from the boiler and it was condensing creosote (from the boiler operating below 140F, which is bad for the boiler....). However, at the end of the first year, I cleaned it all off the door frame (the gooey stuff is really hard to get cleaned off) and have not seen it return. I now wonder if it was clue from the door seal material ? I now make sure my pellet circulator shuts-off at Temp <= 140F, and I'm not seeing that goo on the door frame anymore. So, was it creosote or clue from the factory that first year ? I do not know for sure.
Thanks for sharing your HF60 experiences !
VT_Bubba
Bubba, just recently my hydroflex quit working. I got 5 blinks as an error message which states the igniter failed to fire after 40 mins. Long story short, I had the dealer tech come out and they said a failed sensor (just below the exhaust) and a bad igniter. The feeder would not feed any pellets (possibly because of the bad sensor), so I don't really know how they determined the igniter is also bad. I'm starting to wonder if I have a lemon. Your thoughts?
BMW 22, do you recall what was the cost of the install of your Harman? It seems you have a similar setup to mine with the oil backup. Thanks!
Sounds like you guys are fortunate with your Harman. Unfortunately, I haven't been as lucky. It was installed last December and I've had nothing but problems. I had numerous issues with the installation by the Harman dealer's plumber. He had to bring 2 separate plumbers out, the last one to correct issues with the original plumber. It wasn't heating my home when the temperature would drop under 40. I had to use my oil boiler to heat the house (which is the reason why I bought the Harman). In all, this has cost me around 10k and I'm still using oil. Last week, the boiler stopped working all together. The dealer came out on Wednesday and told me of 3 new problems. The exhaust sensor is damaged. The tech checked it and found scratches on it. These scratches were the result of their tech coming out earlier this year and scraping it with a screw driver to get some ash off of it. This recent tech told me that was a big no-no and is likely the reason it failed. He also said the igniter is bad and will need to be replaced. Lastly, the gasket that goes around the burnpot door has come loose at the bottom (this is the 2nd one).
The dealer said he has ordered the parts from Harman but still hasn't received it. It'd be nice if they kept them on hand like VT Bubba's dealer. Regardless, I don't know why it would take this long even if they had to order them. This week has been cold and the oil has been running and will continue to run until the Harman issues are resolved.
I've got 3 tons of pellets that are taking up space in my garage. This has been unbelievably frustrating for me and my family and it seems as if I'm at the mercy of this Harman dealer. I've asked them for a direct contact for Harman but they won't give me anything and say they are waiting on Harman. I've kept up with the cleaning religously and don't know of anything I can do to make this any better.
Maybe someone from Harman will see this post and be able to help.
Thro9,
Did you ever get your HF60 running satisfactory again ? I can sure relate to your frustrations.
We appreciate your sharing of problems and information !
Thanks,
VT_Bubba
I've officially pulled the plug on the unit (literally). The dealer came back out and are still not able to resolve the issues. I've only been able to use it for about 2 weeks out of approx 2 months into this heating season. The rest of the time I've been waiting on the dealer to come out but they have been out 3 times now and replaced the ESP sensor but the unit failed about an hour later. The most recent time they came out they said the door on the back of the hopper was slightly open and that caused the unit to not come on. It came on only to turn off for good an hour later. I've never even come close to that door so I'm doubting that was really the cause. The door is completely shut now and the unit still won't come on. I've had it with the unit and dealing with this particular dealer. I've asked for a refund on the Harman and am waiting on a response from the dealer. I'd like to mention the name of the dealer here to warn others but I'd rather not go that route at this time.
It's really a shame because I loved the idea of having this unit run properly and run on clean wood as opposed to oil. I guess it wasn't meant to be. I also wonder if it's not so much the unit itself but the dealers inability to diagnose these issues. I've never been able to contact anyone from Harman directly to see if they could diagnose any of the problems. The dealer has had over a year to get these issues resolved and I'm still left with a piece of metal that is just taking up space in my basement. I'd say I've been patient enough. I'll wait to hear the dealers response to my demand for a refund. If they don't honor this request, I'll be taking legal action.
I have five radiant floor heat zones that I would need to keep warm. We are currently burning 6 ton of pellets in two differnet stoves to keep that space warm. Will the Harman Hydroflex 60 be sufficiant? We do have a backup 60.000 BTU gas boiler that seems to be sufficiant when we run it to keep up with the five zones.
Hi again. Well, my wife has said that she wants the 2nd floor warmer than it was last year, so we've been running the oil boiler some. A small pellet boiler could be ideal to heat the 2nd floor, and maybe the basement too if I ever make it habitable.
On another note, doesn't a dump zone have to operate in the event of a power failure? Oh wait, it's a pellet boiler so maybe it's not that much of a factor?
From the service work we have encountered I have to say the Harmon/Heatilator/PB series is kind of spotty. Let's just say they seem to be more of a "hands on" unit than I would like to be responsible for.
Not bashing them at all. They just are what they are which is a product conceived and designed to serve as a back up, not primary heat source IMHO.
