Matt,
I was just looking around the woodboilers.com web site and found some updated plumbing schematics. You need to click on a product type, then look for the documentation tab for that product. You may find the wood boiler schematics more helpful. I tried to attach the PDF file, but keep getting an error on upload.
Good Luck
VT_Bubba
Hi Bubba,
I've been looking through this 2.4 schematic you mentioned earlier. It appears that when you run the pellet (in the schematic cord wood) boiler the weighted check is opened by the pellet circulator, and the swing check on the oil boiler is closed by the same flow. When you want to run the oil boiler you shut off the pellet circulator, and then your zone circs generate the flow through the oil boiler - is that right?
I'd prefer to have the extra circulator on my oil boiler. Basically swap the boilers in this schematic. It works out much better (fewer rework) to my existing plumbing, reduces electricity use since I'll run pellets most of the time, and simplifies my powered dump zone a bit (only one circulator to run for dump). Do you see any drawbacks to this? Note I don't think I would run the mixing valve, so that stuff is out of the equation.
Thanks,
Matt
I know some here are getting tired of hearing me brag (for want of a better word....for me the bulk hopper is a "no brainer" @ $2000.00+-. It flips the time spent on my boiler...IE 90% of my time spent with my boiler is when I want...not 90% of the time being when it needs me...Iceguy...in control of vertical and horizontal....
